How much lift is to much????
  • 16 Replies
  • 5599 Views
Re: How much lift is to much????
« Reply #15 on: October 23, 2006, 01:41:54 PM »
The CJ springs should give you a softer ride and more flex, but to get rid of Axle Wrap you should go with a Traction Bar.
Either that or just three or 4 link the rear.  :D
« Reply #16 on: October 23, 2006, 04:32:23 PM »
Ignore the "I gotta be higher than the next guy" brigade - I am sure they are making up for other  inadequatcies  ;)
ZeusZuki  8)
Yep, big tyres give ground clearance, the trick is to get them on there with the minimum lift. If you're going SPOA consider moving the front axle forward a little to get clearance on the footwells.
Very good example of that is this rig. It is super stable and very capable.
