please help
  • 2833 Views
4x4tracker
please help
« on: October 17, 2006, 08:15:58 PM »
i have a 94 tracker with a 2" calmini lift and i'm looking at some used rims and wondering
if they will work  backspacing and everything
Rock Crawler Series 88
Size: 15 X 8 Bolt Pattern: 5-5.5
Back Spacing: 3.75 Finish: Chrome
« Last Edit: October 17, 2006, 08:46:34 PM by 4x4tracker »
Offline wolf66
  • 193
Re: please help
« Reply #1 on: October 17, 2006, 08:48:31 PM »
yeah they will fit but you may need to do some fender triming to run 30" and up tires or they may rub at full flex...
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: please help
« Reply #2 on: October 18, 2006, 07:08:08 AM »
The rims will fit just fine, but whatever size tires you decide on will determine if they rub. That is the exact same rim measurements I have run on my trucks. One with 2" BL and 1.5" coil spacers with 31" swampers and the other truck has 4"BL, 2" suspension lift and 33" Swampers...
4x4tracker
Re: please help
« Reply #3 on: October 18, 2006, 08:44:07 AM »
thanks runing 235-75-15's
Offline Digger
  • 1991
Re: please help
« Reply #4 on: October 18, 2006, 08:52:05 AM »
Those should work just fine then. 8)
4x4tracker
Re: please help
« Reply #5 on: October 19, 2006, 08:47:34 PM »
thanks again
