Inboarding rear coils???
  • 18 Replies
  • 3924 Views
Offline Chief
  • 678
  • Whaddya lookin at??
« on: January 16, 2005, 11:39:27 AM »
ANyone everythink of inboarding the rear coils?
I'm thinking of fabbing an upper mount right on the bottom of the frame, with a mount right below it on the axle. This would prolly give you about 3" of lift, maybe a bit more.
Anyone try this? Good idea/bad idea? I got some ideas to pull off a bolt on type of thing!  ;D
Offline mesjr2004
  • 422
Re: Inboarding rear coils???
« Reply #1 on: January 16, 2005, 11:54:46 AM »
ya rite now , not using stock springs, but it will give you lift w /stockers not shur how much thow.
Offline Chief
  • 678
« Reply #2 on: January 16, 2005, 12:15:02 PM »
Got any pics? THis a work in progress or are you done?
Offline mesjr2004
  • 422
« Reply #3 on: January 16, 2005, 12:31:36 PM »
work in progress , i got the trailing arm mounts on my toy axel and put it in place and am going to have to remount the trailing arms on the frame making them longer. with the lift the arch of the lower arms is a problem .  :-/
« Reply #4 on: January 16, 2005, 12:34:54 PM »
Inboarding will make your roll more
pronounced, don't do too much permanent
welding until you check it out in a road test
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
« Reply #5 on: January 16, 2005, 01:19:34 PM »
Watch to make sure your lines are ok. e-brake and such, yeah, watch for body roll too. maybe just scrap the whole thing, slap a 5 link on that biotc, notch the frame and aim for a foot of travel or more. Prolly not the best for rock crawling but it'd be fun in the dunes.  ;D
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
Offline Chief
  • 678
« Reply #6 on: January 16, 2005, 01:38:32 PM »
Yea, gonna try and compensate with stiffer shocks. Maybe get a stabilizer bar?  ::)
And it won't be permanent welded in. Should be able to make up a bolt on type of thing!  :o
Offline Chief
  • 678
« Reply #7 on: January 16, 2005, 01:41:27 PM »
What e-brakes??  ???
;D
Offline CBTracker
  • 140
« Reply #8 on: January 17, 2005, 01:06:46 AM »
I"m on glue, don't mind me I wrote that late last night thinking that the ebrake cable runs through there. ???
He he, my bad.
Offline explosivo
  • 3157
« Reply #9 on: January 17, 2005, 03:16:32 AM »
How are you going to make the spring cup deals on the axle bolt-on? :o
omghi2.us[/url]
Offline Chief
  • 678
« Reply #10 on: January 17, 2005, 08:53:09 AM »
Lemme try and see if it works before I say what and people call me stooopid!  ;D
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #11 on: January 17, 2005, 11:09:04 AM »
Once again, why are you doing this?  I all ways thought you wanted the spring out as far as posible for stability?
Is it only for height?
32 MTR's Warn 8000i
Offline Chief
  • 678
« Reply #12 on: January 17, 2005, 11:19:48 AM »
Not for height, Just trying something different for some more flex in the rear. If it drives like sh*t, handles like sh*t, just plain is SH*T, I'll go back to stock. I have no plans on cutting off the stock stuff.
And what's up with the once again?? Did you ask this before?
« Reply #13 on: January 17, 2005, 10:56:55 PM »
I've seen this done on a coiled Sammi - the axle bent :o, several times  :o :o.
Hey - 500 posts!!!!
« Last Edit: January 17, 2005, 10:57:27 PM by Rhinoman »
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #14 on: January 17, 2005, 11:11:34 PM »
I was just trying to figure it out in my mine.  So "once again" I was trying to figure it out.
What shocks are you running?  Those are your first limiting factors.  Once you have long enof shocks to where your spring are loose then your springs are your limiting factor.
But,
I have a set of Ford F-150 4x4 shocks on mine.  Calimni 3" springs set to where their loose and I don't think I'd want any more drop.  I/we have a slip yoke, and any more drop and I'd be worried about the drive shaft coming out to far.
Flexing over rock and such would not be a problem, but hitting a jump at 20-30 mph and getting a little air, the whole rear end cycles down and ???
Also, I remember Mike stating once that at one time he had too much articulation in the rear for the front IFS.  It was unstable.
32 MTR's Warn 8000i
