Rock Sliders
  • 16 Replies
  • 7425 Views
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
Rock Sliders
« on: January 15, 2005, 07:56:34 AM »
Thinkin about making some sliders. Any have any suggestions on what to do, not to do, or any design ideas that they regret about their sliders? wishlists? I've herd of tow tabs, sounds good, not for actually towing but for stablizing on offcamber situtions.
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
Re: Rock Sliders
« Reply #1 on: January 15, 2005, 08:43:20 AM »
just try to keep them as close to the body as possible and nothing underneath them for rocks to hang up on, and I would have them stick out the side a little so you could use a high lift jack on them.
the_dude
Re: Rock Sliders
« Reply #2 on: January 16, 2005, 01:39:18 PM »
I like the look of the shrockworks sliders he does for samurai's it appears that they are in development and sees like they are going to stay in development cause it's been on his site for what seems like forever.
I was thinking about running the metal all the way to the frame at an angle. It's not my idea I saw it on one of the RPM 4x4 guys trucks. It was either Hagen or Chunk but I can't remember.
If you have ever seen Hawks sidekick he used a large pipe like 8 inches and cut it in half and matched to the body line It looks pretty cool too.
Offline cj
  • 1276
  • I drive a really big ATV
Re: Rock Sliders
« Reply #3 on: January 16, 2005, 08:26:34 PM »
I have just put sliders on my 4dr and have barely lost any clearance and they don't go to the chassis and nothing to hang up on 8) Haven't got any pics at the moment but will take some and post them when I get a chance.
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Rock Sliders
« Reply #4 on: January 17, 2005, 12:27:08 AM »
Mine were a 1-off by Spidertrax.  It's awesome, having a major Suzuki shop within about an hour drive time!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline CBTracker
  • 140
Re: Rock Sliders
« Reply #5 on: January 17, 2005, 12:57:51 AM »
I"m thinking of something similar to bobzukis's sliders. I have round stock though so it'll be slightly different. I'm just wondering the best way to mount. I've herd welding and drilling into the frame prolly doesn't help its strength so I'm pondering a two plate bolt around system that will sandwich the frame. Any experiences Good/bad about this? anyone know how to get the slider tight against the rockerpannel and still get around the body weld that runs the length of the truck? also what kind of reinforcement is behind those things.
could you put some jerrycan's underthere? or a sleeping bag? or a package of white power??   JK  ;D    :o
Re: Rock Sliders
« Reply #6 on: January 17, 2005, 01:28:20 AM »
Dont go cheap, and if you build your own make sure your decent at welding.
You can see just above my slider a crushed rocker. It was caused by using to small of a support and it breaking at the weld. Now that I have the 2x4 slider (shown in pic) I have not had any trouble.
« Last Edit: January 17, 2005, 01:34:30 AM by Zukipilot »
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Rock Sliders
« Reply #7 on: January 17, 2005, 02:09:06 AM »
You're right about the with most frams.  Like GM and Ford their "C" canaled forged harden steel.
Our Zooks are a mild squar tub frame.  If you looke you can see where the front and rear are welded to the frame.
You can weld with no problems to this frame.
« Last Edit: January 17, 2005, 02:21:20 AM by lil_Truck »
32 MTR's Warn 8000i
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Rock Sliders
« Reply #8 on: January 17, 2005, 02:19:53 AM »
I had already damaged my rockers when I decied to make some sliders.
I folded the rocker lip over and built a slider to go around the rocker.
It goes up the side, across the bottom and back up to the body suports.  Then I have two arms going to the frame.  When I installed it I siliconed it to the body where the two touched and then welded it to the frame.
They work great!  And I can use a jack to lift the whole truck with them no problems.
I based it off of this one:  http://www.izook.com/tech/tracker/jimmrocrails.htm
32 MTR's Warn 8000i
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Rock Sliders
« Reply #9 on: January 17, 2005, 02:22:06 AM »
32 MTR's Warn 8000i
Re: Rock Sliders
« Reply #10 on: January 17, 2005, 02:37:03 AM »
I'm weld3ed to the frame with no problems
Offline Natebert
  • 1098
Re: Rock Sliders
« Reply #11 on: January 17, 2005, 02:44:55 AM »
Buddy of mine did the 2 bolt above, 2 bolt below and it was wobbly and started to crush the frame.  (I'd suggest if you wanted a bolt on to use collars).  He did a weld on after that and it was SOLID.
~Nate
Offline cj
  • 1276
Re: Rock Sliders
« Reply #12 on: January 17, 2005, 08:47:57 PM »
Here's some pics of my new sliders. As you can see there is nothing to catch and almost no clearance lost.
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Rock Sliders
« Reply #13 on: January 18, 2005, 12:35:38 AM »
Yeah, but...
Those are just screwed onto the body!!!   :o
Do they work?
I guess I just always figured they had to be welded to the frame...  Guess I'd be afraid of ripping the body off the frame, when I dropped down on 'em hard!
Bob
Offline HUMZUKI
  • 117
  • Fool!
Re: Rock Sliders
« Reply #14 on: January 18, 2005, 12:47:14 AM »
The weight will destribute, you'd have to bend that 1/4" (looks like 1/4"). Very nice. Did you make those? I just welded some 3.5"X.25" angle iron to the side of my samurai. The only down side of doing it like this is, that the weight puts alota stress on the body mounts but I havent been able to break anything yet.
