Air Fuel Gauge
  • 1369 Views
Offline fullsink18
  • 250
  • Wheel Me!
Air Fuel Gauge
« on: October 20, 2006, 06:44:47 AM »
I am thinking about getting one of these gauges. One question, does a sidekick have a narrow band O2 sensor.  I am pretty sure it does.  But I want to be sure.
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Re: Air Fuel Gauge
« Reply #1 on: October 20, 2006, 08:44:36 AM »
Yep, narrow band. I have used one of these gauges in the past and they're not very effective. The narrow band sensor switches very rapidly between reading rich and reading lean, it also has a relatively slow response time and is quite temperature sensitive. For WOT and idle it is no good, it can be quite good for tuning off load once you get the hang of how it works. If you can hook it up to a datalogger then it is much more effective. The money would be better spent on a dyno session, otherwise the plug colour and a stopwatch is hard to beat.
« Last Edit: October 20, 2006, 08:46:38 AM by Rhinoman »
