clutch slipping on 97 sidekick 4dr
  • 1472 Views
Offline havoc1969
  • 24
« on: October 25, 2006, 05:41:44 PM »
had aamco put in a new autozone clutch, pilot bearing, the whole nine yards,,, it doesn't seem to slip in first, but slips in all the rest when I give it more gas.  If I ease up on the gas, the rpms drop down....
how do I fix this...
Offline havoc1969
  • 24
Re: clutch slipping on 97 sidekick 4dr
« Reply #1 on: October 26, 2006, 06:11:46 AM »
no advice?? help!!!
Offline 89tintop
  • 356
« Reply #2 on: October 26, 2006, 07:43:52 AM »
take it back to them, if you paid to have it installed then you should not have to figure out how to fix there mess up, if they dont fix it or give you your money back then off to the better bussiness bureau I would go.
« Last Edit: October 26, 2006, 07:47:04 AM by 89tintop »
91 kick 4 door 2 inch body lift, 2 inch spacer lift, 31's.
Offline havoc1969
  • 24
« Reply #3 on: October 26, 2006, 04:23:22 PM »
thanks for the advice.  I called them this morning, they came and picked it up from my work, readjusted it, and returned it, all in a few hours!! That is what I call customer service.  Now the clutch works just as it should, however the clutch pedal does not return all the way up to the top, and they said I need a return spring for the clutch cable?  Anyone know where I can get that so as I can be done with this?
