(Track/Kick) + (1.6 - 1.3 engine/tranny adapter) + (sami tranny and tcase) = ???
  • 3085 Views
Offline Element
  • 1902
  • LillyKicker
Could this be done? And would this be a solution to the problem of finding gears???
zUkTAH
U4WDA
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
i have seen pictures of it, somwehere....
Anything can be done with enough $$$$ or skills.
Another solution may be.....trackick 1.6, trackick 1.6 2wd tranny, samurai tcase.  Since the samurai tcase is divorced, it really doesn't make much sense to use a samurai tranny (IMO).  You would need to make an intermediate shaft and fab up some frame mounts for the samurai tcase, of course.
Offline Element
  • 1902
  • LillyKicker
Are the 2wd trannys readily available? We have extra sami stuff laying around...That is why I posted the inquiry. Seems that no one has much for tracker gears....
zUkTAH
U4WDA
2wd's don't seem to be as common as 4wd's.  But I do see them around somewhat regularly.  I probably run across at least one 2wd trackick, every 2 or 3 months.
Are you talking tracker tcase gears, as far as no one having much?  If so, I agree, I think the only tracker tcase gearsets you can get are the 4.24:1's, which are higher in cost than the 4:1 samurai sets.  So if you can add the samurai tcase in for little to no $$$, then you could turn around and buy a samurai tcase gearset and still have less money invested than just buying the tracker tcase gears.
Offline Element
  • 1902
  • LillyKicker
Thats what we were thinking... keeping it simple and cheap.... we have and you can find stock anywhere.
zUkTAH
U4WDA
