sammy 5speed w/t-case in tracker/sidekick
  • 20 Replies
  • 5192 Views
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« on: October 26, 2006, 06:11:56 PM »
Has anybody done this? Ideas? Im trying to get the lowest gear ratio possible for my tracker.
If you could couple a 1.6 kick engine in a sammy, why couldn't you put a sammy 5 speed with sammy t-case in a kick?driveline angles ?, Fabbing up mounts would not be a problem.
Any other concerns?
TJ
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline Element
  • 1902
  • LillyKicker
Re: sammy 5speed w/t-case in tracker/sidekick
« Reply #1 on: October 26, 2006, 06:16:49 PM »
LOL, Hey TJ I beat you to the post!!! Maybe since there are two posts it will double our chances of finding this out!!!
Jerry                                                               Member since:   May 14, 2006
zUkTAH
U4WDA
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #2 on: October 26, 2006, 06:26:19 PM »
Thats funny,  I hope somebody out there has some info on this.(I think I need some coffee it's gonna be a long night)
#801-554-3281
Offline Skyhiranger
  • 3734
  • 122
« Reply #3 on: October 27, 2006, 09:39:18 AM »
Any other concerns?
TJ
If you are going for the lowest possible gear ratio.....keep the trackick engine, tranny and tcase.....then add the samurai tcase behind that.  Regear your diffs to 5.12, if they aren't already (or 5.38, if you can find them).  Put 4:1s in the tracker tcase, put 8:1s in the samurai tcase, then you can start breaking stuff.  ;D
« Reply #4 on: October 27, 2006, 10:09:28 AM »
Wow... that would put the user just a bit lower crawl ratio then I have right now... and that is while they are in 4th gear...  :o
 ;D
Offline Element
  • 1902
  • LillyKicker
« Reply #5 on: October 27, 2006, 11:13:06 AM »
The idea is to go a little lower and to have gear options.
zUkTAH
U4WDA
« Reply #6 on: October 27, 2006, 11:29:48 AM »
I think simply have a 4:1 Sammy T-Case behind the stock Tracker T-Case with 5.12 gears will give you plenty of options.  That gives you a 2:1, 4:1 and 8:1 options allowing you to go down to 160+ for your overall crawl ratio.  Throw in an automatic transmission and you should be able to go as slow as you need.
Offline Element
  • 1902
  • LillyKicker
« Reply #7 on: October 27, 2006, 12:04:48 PM »
Do you have to do some cutting on the tracker tcase? I know there is the ott and kicker3 out there. We were wondering if there was any other alternatives that would be cheap. A few of us have some extra sami parts laying around ....
zUkTAH
U4WDA
Offline Skyhiranger
  • 3734
  • 122
« Reply #8 on: October 27, 2006, 12:24:04 PM »
Yeah, that is what you would be doing....basically building a kicker 3 type setup.  The front output would need to be cut off the tracker tcase for clearance of the front driveshaft.
« Reply #9 on: October 27, 2006, 02:28:35 PM »
You can do it, there are a couple posts talking about it.  The only one I was able to find quickly was from a few years ago.
Linkitude
Offline Element
  • 1902
  • LillyKicker
« Reply #10 on: October 27, 2006, 02:31:15 PM »
I am trying to find stand alone set up...
zUkTAH
U4WDA
« Reply #11 on: October 27, 2006, 02:42:41 PM »
Like switching to a divorced transfer case?
Offline Element
  • 1902
  • LillyKicker
« Reply #12 on: October 27, 2006, 03:07:15 PM »
The topic is titled : : sammy 5speed w/t-case in tracker/sidekick. A few of us wanted to know if this is possible...
zUkTAH
U4WDA
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
« Reply #13 on: October 27, 2006, 04:22:47 PM »
you do this.
Offline Element
  • 1902
  • LillyKicker
« Reply #14 on: October 27, 2006, 04:25:42 PM »
Details please. What is all done?
zUkTAH
U4WDA
