how to make aftermarket gauges work off ecm?
  • 2357 Views
Offline 95_geo
« on: November 01, 2006, 07:05:48 AM »
does anyone know if the pins from the ecm have the same range/signal as aftermarket gauges?  if not then ill have to run new taps,  i was just thinking that it would save a lot of time and hassle if they worked.
 im looking at autometer if that helps
i.e. fuel level, oil pressure (is it a pressure switch or is variable) tach, volt meter, ECT.
im in the process of a 2.7L swap and i figured its a good enough time to go to better gauges than "H-C"  ;D
Re: how to make aftermarket gauges work off ecm?
« Reply #1 on: November 01, 2006, 10:13:14 AM »
I'm not familiar with the ECM on the 2.7 and I'm not aware of an FSM or schematic on line. I would suspect that it would be much better to add the sensors that come with the gauges. There is a high risk that adding the gauges across the ECU pins or across the stock gauges will alter the electrical characteristics.
Offline rockrat
  • 196
  • Got Ringr
« Reply #2 on: November 01, 2006, 09:54:15 PM »
Bryce
negative on the fuel.. You have to get a sending unit to match the autometer. The tach is posable, but I think you would be happier with Mechanical guages instead of electric. I ran the entire Auto-meter ultralite series in my buggy and in the Kimera project
Offline zuk1972
  • 102
  • middletown ohio
« Reply #3 on: November 05, 2006, 07:39:55 AM »
  The tach is the same wire[aftermarket or stock] brown/white stripe[on tracker- sammy i believe and  comes from the - coil in any case [internal on newer efi][double check] the gas tank,oil pressure,volts/amps and water sensor[gauge]-not the cts it is thru ecm are non ecm routed straight to the cluster....The resistance will be different and effect the gauge operation you will need to t off and run the right senders for the gauge supplied with the gauges...
