Tracker stalling!
  • 1702 Views
Offline jamescraft34
  • 51
Tracker stalling!
« on: November 01, 2006, 10:19:43 PM »
So I have done some seaching in this forum on the stalling problem and I guess I don't understand a lot of the suggestions?
NOT all the time, but sometimes my 96 Tracker will stall out when the clutch pedel is pressed.  It usually happens when I am stopping, or if I press the clutch in during normal driving and let the rpm's wind down...
I thought maybe the EGR valve was the reason, so I replaced it with a used one from Hawk Suzuki.  I even made sure to clean the carbon buildup in the used one before I installed it.
Does anyone have any good suggestions as to where to look now?  I have read so many suggestions and am not sure what to do?  Also I am not getting any check engine lights so I imagine I do not need to check for any codes.
Oh yeh, I also replaced my spark plugs and wires, fuel filter, and even sea foamed it in hopes any of these might help...
Not sure if this info will help, but I usually only get about 21 miles a gallon and I am running 30x9.5 tires. Thought these Trackers got better MPG?
Any suggestions would be awesome!
Thanks!
« Last Edit: November 01, 2006, 10:22:15 PM by jamescraft34 »
Re: Tracker stalling!
« Reply #1 on: November 02, 2006, 12:00:21 AM »
   My 95 had similar problem.  I adjusted the Idle Air valve and its been fine since.  My gas mileage was never that bad however.  Here's a couple links with more info on the adjustment.
http://bbs.zuwharrie.com/content/topic,31656.0.html
http://bbs.zuwharrie.com/content/topic,23815.0.html
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: November 02, 2006, 07:07:46 AM »
I adjusted mine too, following the same directions, mine doesn't stall now, and it hits 1500rpm for about a minute during warmup. It will still drop in rpm sometimes when I stop at a light, but it only drops to 600rpm, then it jumps back to normal 800rpm idle.
