2004 Vitara daytime running lights
  • 21 Replies
  • 15735 Views
Offline the_maplebar
  • 466
Re: 2004 Vitara daytime running lights
« Reply #15 on: January 30, 2006, 07:34:41 AM »
Their are 2 different (headlight) things that bug me about these cars and and 2 different ways to deal with them.
DAYTIME RUNNING LIGHTS (DRL): This is only mildly annoying (IMO) and I only care about turning them off every once in a while.  Looking at christmas lights, drive in theater's etc.  In this case the easiest thing is to leave the parking brake up 1 click so the light is on, BEFORE you start going.  If you pull the parking brake up after the DRL have already come on, they won't turn off.  If you want something more permanent then you have to get into the wiring and/or pulling fuses.  I have 3yrs and 55,000 miles on my tracker and have never burned out a factory headlight yet.
AUTOMATIC LIGHT CONTROL (ALC):  This i find very annoying, especially since it comes on anytime it is not really bright out.  The easiest solution: pop the ALC sensor out of the dash using a small screw driver or pocket knife and unplug it.  ALC will never come on again.  This way you also maintain the safety feature of the DRL in case that is ever an issue.
« Reply #16 on: January 30, 2006, 07:44:32 AM »
DRL's are a safety feature, not because
you don't know when to turn on your head
lights, it's to help keep you from becoming
a road pizza on some barren stretch, and
this also protecting your Zuke for future
generations to use and enjoy
Offline mojoincolorado
  • 95
« Reply #17 on: February 01, 2006, 10:50:27 AM »
DRL's are just for the lame.  If you are out alone on a highway, and someone comes the other way and doesn't see you, DRL's are not going to come to the rescue -- they were going to run you over anyway.  And drunks (though less are out in the day time) and tired drivers tend to drive into the light.  That's why if you look at Schneider trucking company trailers they have blue and silver reflectors with grids that point down and to the left on the rear of the trailers.  That's also why some of the cop car light bars tend to steer you to the left by flashing in a subtle arrow (lights strobe to the left).
On another point, if you are driving in a metro area with all the eye trash out there, what is one more (or two more) lights going to do to get your attention amongst the glare off of car windows, chrome, signs, building windows, etc?
I think that if only a few cars have there lights on, it's great for them, but if everyone has there lights on that it just makes it more difficult to pick out the true condition of what's going on, even to the point of not seeing deer, dogs, and kids.  By the way, OBD2 doesn't know if drl is on or not (I suspect that it wont know if the headlights are on either).
More eye trash is not necessarily better eye trash, it just takes your attention from a lot of other things (and may even wash out the subtle but more important details).  To illustrate, I was walking in downtown Denver a few years ago.  I got to a cross walk and looked both ways.  Fortunately I looked again, because I had a street car bearing down on me.  It had DRL, but so did the cars, and the glare off of the wires, windows, signs, etc, kept me from noticing it.  Could have been smashed to bits and not been here to rail against the sheepherding guboment do gooders!
I think my soapbox broke, but since I don't have any DRL to see by I may be gone a while.... 8)
Offline tOnKa TrAcKeR
  • 264
  • support our troops
    • Cardomain site
« Reply #18 on: February 01, 2006, 11:55:10 AM »
im sure that the OBDII does know when your DRLs are on because I have plugged an GMtech II into a 99 tracker and cut the drls on and off with the tech II
anyways this thread is over a year old
mozone
« Reply #19 on: February 01, 2006, 06:35:02 PM »
 i like to sit in my vitara in the mornig for about 10 min or so before i go into work. the alc is a pain. no one wants to sit parked with the head lights on. also when i go hunt in the mornig its nice to be able to cut them of before  i get to close to my stand :-\
Offline Gemini
« Reply #20 on: April 01, 2008, 02:51:41 PM »
Ok... so, what I'm reading is that nobody actually knows how to disable them? The plug under the steering column isn't an option on the 2004's... I tried it today, and that nice silver box isn't there. There is 1 plug on the side.. it's white with a black tape piece around it... and when you haul that out, the lights stay on no matter what the handbrake is doing, and you lose the door ajar beep, among other things. What I need to know is the actual location of the DRL module. On my '03 Lancer, it was on the inside fender wall behind the drivers side headlight... as seen below... So, if anyone knows the location of this module on an '04 Grand Vitara, please let me know.
Thanks!
My 2004 Suzuki Grand Vitara JX build-up thread: here:
My 2003 Mitsubishi Lancer OZ-Rally Edition build-up thread: here:
« Reply #21 on: April 02, 2008, 04:41:19 AM »
When stopped you can turn off the headlights by pulling up slightly on the emergency brake.  I have had a car with them and found that you do get used to them after awhile.
On my Zuk themparking brake switch is also an input to the ECU. I haven't worked out what effect its supposed to do because the wire broke off.
