maybe a stupid question
  • 2411 Views
Offline kirknd4spd
  • 333
« on: November 05, 2006, 10:02:33 PM »
ive read that track/kick ring and pinions (and possibly 3rd members) can be swapped into a sammy. so...can samurai ring and pinions be swapped into my 89 sidekick? what about the 3rd members? i still have the 10 bolt axles with stock gearing, but need lower gears, and would like 5.83's, but they're impossible to find for a sidekick. however, a friend of mine is giving me the axles out of his samurai, since he's swapping in dana 44's, and id like to use the gears out of them (they have 5.83's) in my sidekick. thanks.
Offline 4njeep
  • 113
  • I Love ZUKIWORLD!!!!
Re: maybe a stupid question
« Reply #1 on: November 05, 2006, 10:13:57 PM »
the sami ring and pinion will fit in the front 3rd of the tracker, but not in the rear, the rear is much larger in size. and i beleive that the rear 5:83 for the sidekick 3rd are really hard to find.
92 sidekick jlx auto
2" suspension lift
5.13 gears, locked rear.
30x9.5 goodyear mt/r's on CSA Scorpion's
Offline wheresmyhat
  • 244
  • 16v here I come baby!!!
« Reply #2 on: November 05, 2006, 10:26:55 PM »
The sidekick tracker rear ring and pinion is huge compared to the sammi so the rear is out of the question. Read this, it will help answer your question.
http://bbs.zuwharrie.com/content/topic,3975.0.html
You may or may not of read this posting but it should explain why you would not be able to.
Hope it helps at least a little.  ???
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
Offline kirknd4spd
  • 333
« Reply #3 on: November 06, 2006, 10:17:11 PM »
ok, thanks. do you know where i can get some lower gears? ive never seen 5.83's for a 10 bolt track/kick, only 12 bolt.
Offline malodin
  • 17
« Reply #4 on: November 06, 2006, 11:31:27 PM »
could it be possible to swap the rear samurai axle into the sidekick? i dont think it would be to hard to weld on the necessary spring perches and stuff?
alex
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #5 on: November 07, 2006, 05:17:35 AM »
alex
The TracKick Transfer case has a centered rear output.  Thus, the TracKick rear axle's differential is also centered, so you have a driveshaft problem if you use a Samurai rear axle on a TracKick.  Then there is a possible width problem, a possible structural strength problem...
You might have better luck getting a 12-bolt TracKick axle with 5.83s  -- assuming such an animal exists.  kirknd4spd's post suggests that such an axle exists.  Personally, I don't know if it does.
Hope this helps
Ack
« Reply #6 on: November 07, 2006, 07:41:07 AM »
Calmini don't list the 10 bolt rear 5:83s but I have them in my Vit. IIRC they used to list both types, I guess that they stopped the 10 bolt version.
Offline kirknd4spd
  • 333
« Reply #7 on: November 07, 2006, 10:15:46 PM »
yeah, calmini doesnt make them for 10 bolts anymore. so i guess i need a 12 bolt? anyone wanna donate one?
