Help, someone messed this up!!!!!
  • 1493 Views
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« on: November 12, 2006, 09:46:27 AM »
I swapped with a guy to get a tintop. I found the choke mechanism had come loose and wedged. I fixed it and am trying to reroute and correct the emission hoses. Some are plugged with screws, missing or misconnected. Some of the switches are missing or broken. One of the hoses was pinched under the valve cover gasket. I pulled the valve cover gasket, and two of the rocker arm screws are missing. Oil leaking out of the distributor. I pulled it and the extension housing. There is no o ring for the extension housing.
I can get the orings from petro works but I also need the two (out of 10) rocker screws and I could really use all the emission switches and hoses. I have the ack page and am slowily figuring it out but with out the parts, I am at a standstill. I posted in the want ads as well. Any help appreciated. Adam
Offline daddyizzle
  • 728
Re: Help, someone messed this up!!!!!/still w.t.b. emission parts
« Reply #1 on: November 17, 2006, 07:08:27 AM »
Hi. I'm still looking to buy the original emission hoses valves etc. Just trying to make her run like she's supposed to.
If anyones doing a weber conversion and getting rid of the emission stuff, let me know.
-Adam
« Reply #2 on: November 17, 2006, 07:30:24 AM »
Adam,
Give Hawk Strictly Suzuki a call at 1-888-SAMURAI. Rick and his staff can get you whatever you need.
