Lost timing?
  • 3156 Views
Offline raydel
Lost timing?
« on: November 13, 2006, 09:58:51 AM »
PULLED HEAD ON MY '87 SAMMI, FOR GASGET & VALVE SEALS
BACK TOGETHER NOW IT'LL ONLY TURN OVER.
GOT SPARK GOT GAS ADJUSTED DISTRIBUTER TO #1 PLUG WIRE WHILE AT TIMING MARK.
WHAT AM NOT DOING.
Re: Lost timing?
« Reply #1 on: November 13, 2006, 10:38:48 AM »
You're 180 degrees out on the cam timing. Try pointing it to no 4 instead.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Lost timing?
« Reply #2 on: November 13, 2006, 11:00:50 AM »
If you have the spark plug wires back on as they were before you removed the head, you need to open the timing belt cover, remove the timing belt  and turn the camshaft EXACTLY 180 degrees clockwise from where it is now.  Re-install the timing belt and everything will work.
The thing to remember is that the crankshaft turns twice to every turn of the camshaft.
Following the various manuals, they will tell you to make the arrow marks on the cam and crankshaft point up, which is correct.
Sometimes the camshaft has two "arrows" - or you try setting the crank and camshafts so the arrows point at each other (up and down) via instructions in some voo-doo BS Internet post.  The result is that the camshaft ends up 180 degrees off.  The lazy fix for this is to re-wire the sparkplugs 180 degrees out to compensate.  Bogus idea in my opinion...  EDIT: (sorry Rhinoman)  The right way cuts down on confusion down the road when you have to work on the engine again...
Hope this helps!
« Last Edit: November 13, 2006, 11:06:00 AM by ack »
Ack
Re: Lost timing?
« Reply #3 on: November 13, 2006, 12:10:35 PM »
Hope this helps!
Thats true but swapping the leads or timing it to no 4 will confirm that that is the problem before you pull the timing belt again.
Offline ack
  • 1659
    • Ack's FAQ
Re: Lost timing?
« Reply #4 on: November 13, 2006, 04:23:16 PM »
Hope this helps!
Dang it!
You are right again!
Can you help me pull my foot out of my mouth?????   ;D
Ack
Offline RGERBER
  • 81
Re: Lost timing?
« Reply #5 on: November 13, 2006, 05:40:04 PM »
I am having thae exact same proplem, did you check your centrifugal advancer- gently turn your rotor clockwise it should spring back.. mine will not. i am going to check my spark soon as someone gets home.
let me know i am wondering if i need a new distributor
94 SUZUKI SAMURAI / 1.6 8 VALVE TRACKER MOTOR.
Offline RGERBER
  • 81
Re: Lost timing?
« Reply #6 on: November 13, 2006, 06:10:50 PM »
I HAVE SPARK.. SO I SWITCHED THE # 1 PLUG WIRE WITH THE # 4 WIRE- HAD TURNED THE DISTRIBUTOR A LITTLE AND IT STARTED RIGHT UP.
THE ROTOR WAS POINTING JUST A TAD LEFT TO # 1 SO THATS RIGHT- THAT MEANS THE TIMING MARKS ON THE CAM AND CRANK ARE OFF - NOWAY I DOUBLE CHECKED
WINDOW LINE WAS ON TDC CRANK WAS ON TDC AND CAM WAS ON TDC AND CAMLOBES ON # 1 were closed.
Re: Lost timing?
« Reply #7 on: November 14, 2006, 04:56:22 AM »
Its a Zuk thing, I don't know why but this happens so many times.
Offline raydel
Re: Lost timing?
« Reply #8 on: January 02, 2007, 04:12:10 PM »
yep it was all jacked up
got to the point of  starting all over then used all the advise given here & and she cranked up just fine
thanks guys
