CV elimination?
  • 2917 Views
Offline MKOLSEN22
  • 217
  • Come on 32's
CV elimination?
« on: November 13, 2006, 10:30:09 PM »
I was just thumbing through an old Downey Off-Road catalog for Toyotas and came across the kit in the following picture.  Has any one done this for the track-kicks?  Might be a cool upgrade to eliminate the weak inner cv joint assembly.  What do you guys think?
Boy do I wish I had my lathe here.
Re: CV elimination?
« Reply #1 on: November 14, 2006, 04:46:14 AM »
Wild was considering something like that.
Where is Wild?
Re: CV elimination?
« Reply #2 on: November 14, 2006, 12:32:42 PM »
Where is Wild?
Good question. I have not seen him recently  :-\
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
Re: CV elimination?
« Reply #3 on: November 15, 2006, 05:41:27 PM »
ifit replaces the inner part of the axle , there not weak , ive never broke the inner always the outer part . though the idea of having the slip joint would be cool.  stan
Offline ZeusZuki
  • 411
Re: CV elimination?
« Reply #4 on: November 15, 2006, 07:56:01 PM »
Funny you should bring this up. I am looking into the same set up as we speak.
It is something that can be built with relative ease. Parts are pretty easy to source.
MOST IMPORTANT THOUGH: If they are designed properly then they could be a universal fit for 1600 Kicks / Widebody Vits and GV's - one size fits all  :D ( GV and widebody Vits have longer half shafts than the 1600's ).
Dana assemblies use the UJ type joints and seem strong enough so why wouldn't it work? - I do not see why not  ;)
ZeusZuki  8)
« Last Edit: November 15, 2006, 07:57:55 PM by ZeusZuki »
Offline MKOLSEN22
  • 217
  • Come on 32's
Re: CV elimination?
« Reply #5 on: November 16, 2006, 04:43:17 PM »
I was also thinking that with this set up you could run a driver side flange on the passenger side.  Then let the slip portion of the axle make up the difference in length side to side.  Make up a third axle and keep as a spare.  Maybe source flanges that use the same u-joint as the rear drive shaft and only cary one spare to cover all of them.
Thoughts?
Offline barcus
  • 97
  • fun
Re: CV elimination?
« Reply #6 on: November 16, 2006, 08:49:15 PM »
wow very nice... for what year toyota axles are these? will this be an easy swap if you have stans toyota CV swap kit?
Offline MKOLSEN22
  • 217
  • Come on 32's
Re: CV elimination?
« Reply #7 on: November 16, 2006, 09:24:19 PM »
The Downey kit fits Toyotas from 1986 to 1995.  Here is a link to Downey's web site.  Scroll down to almost the bottom and you will find this kit discussed.
http://www.downeyoff-road.com/SuspensionComponents/index.htm
