Noisy front end after front strut install - 96 Tracker
  • 1653 Views
Offline sklope
  • 135
  • BUSHWACKER
« on: November 17, 2006, 07:09:45 PM »
Just installed new struts and the front end makes noise when turning sharply after the vehicle has set a while. The noise sounds like a bushing rubbing. Had the front end aligned and the mechanic said that it sounds like it may be the upper bushing on the struts. He said that I may want to put grease or vasoline on the bushing. Has anyone else had this problem and if you did is this how you repaired it??? Thanks!
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
* Custom front and back bumpers
* Durabak exterior coating (bed liner) * '07 chevy silverado "wail tail" tailgate cover (custom cut to fit)
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Noisy front end after front strut install - 96 Tracker
« Reply #1 on: November 17, 2006, 08:38:02 PM »
If the top nut wasn't tightened correctly, then the top strut mount might make a squeaking noise.  When you loosen these, and the strut shaft turns with it, it makes a squeaking noise.  I'd be checking over the bolts and make sure they're tightened correctly.
You shouldn't need any grease at all.
1993 4-door Sidekick
4.24:1 t-case
Offline sklope
  • 135
  • BUSHWACKER
« Reply #2 on: November 20, 2006, 11:17:05 PM »
Checked the top nuts on the struts today. Found out that the washer that fits over the bushing was upside down ::). After flipping these washers and tightening the nuts back up, NO NOISE!!! Thanks for the help ;D!
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
