Loss of fuel economy as I drive longer
  • 2276 Views
Offline r3cc0s
  • 321
« on: November 18, 2006, 09:21:09 AM »
I can understand power/fuel effecency loss if an engine gets too hot... affects compression and what not
What I have found was this...
For my first 3 hours of a drive, the MPGs I get is quite reasonable
If I stop for a few hours and then continue, same thing it's not bad
If I however continue driving (as I did yesterday for a 6 hours return trip)
The first 3 were fine, I then refueld, and tried again and I'd have to say was at the last 20-30% worse than the inital 3 hours
the engine temperature was fine (hovering below half as usual), and I seemed to have absolutely no power loss
Yesterday I checked my anti-freeze, and everything sat well in the tester
I changed my oil w/ more synthetic oil
I changed my air filter, sprayed down the throttle body with cleaner and pourd a gas treatment in
this is quite puzzleing
Offline IanL
  • 466
Re: Loss of fuel economy as I drive longer
« Reply #1 on: November 18, 2006, 03:21:28 PM »
That's hard to explain, unless you were climbing hills on the second stretch.
Offline r3cc0s
  • 321
« Reply #2 on: November 18, 2006, 03:41:15 PM »
nope... coming back the same way
Offline IanL
  • 466
« Reply #3 on: November 19, 2006, 03:30:15 AM »
Ah, I missed that inference.  Is the halfway point lower altitude than the start/ finish point?  If so, you went (on average) downhill outbound, and uphill on return.
If not, it has to be the wind.  Travelling with the wind outbound, and against it on the return.  Check with the weather service  ;)
« Last Edit: November 19, 2006, 03:33:38 AM by IanL »
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #4 on: November 19, 2006, 09:50:46 AM »
So many facters come into play. Ellevation, hill, ur right foot too. I use to notice the same when going back and forth on the same road
01 GRAND VITARA
