Speedo Correction
  • 2281 Views
Offline ngrover
  • 131
Speedo Correction
« on: November 19, 2006, 01:22:10 AM »
I've heard of people using the "Yellow Box" to correct their speedo. I'm wondering if anyone has used or heard of the "SpeedoHealer"? According to their site:
"Fits ALL cars with 3-wire speed sensor and with 2-wire ground switch sensor"
http://www.speedohealer.com/eng/intro.htm
I'm trying to figure out if this would work on our Grand Vitaras as it's a little bit cheaper, has finer grained adjustability, and there is a Canadian distributor.
2000 Suzuki Grand Vitara, 5spd. 2.5 inch lift, 225/75R16 AT's
Offline IanL
  • 466
Re: Speedo Correction
« Reply #1 on: November 19, 2006, 01:47:18 AM »
The wiring diagram shows a single wire, blue/yellow stripe, between VSS and speedometer.  So it sounds like Case 2.
Only one way to find out  ;)
Btw, I have found out that my speedo reads 5mph fast at 70 mph on stock tires.  So if you fit tires with 6.66% larger diameter, you would be spot-on!
