Samurai MPG
  • 13 Replies
  • 4614 Views
Offline Amilla
  • 1076
Samurai MPG
« on: November 20, 2006, 03:12:33 PM »
What are you guys getting on your samurais?
Offline Heiny57
  • 24
  • Coming soon!!!!
Re: Samurai MPG
« Reply #1 on: November 20, 2006, 05:07:07 PM »
2 trails, 6 hills, 3 mudholes, 1 reverse out of mudhole, 1 highspeed attempt at 3rd mudhole, 1 tow back to trailer per gal.
 ;D
88 Samurai ( stock for now)
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: Samurai MPG
« Reply #2 on: November 20, 2006, 08:27:31 PM »
Hi. 1.3 with stock carb and a bunch of hoses blocked or misrouted or missing, and the choke messed up and the idle way too high.
I got 27 mpg on a 300 mile + drive. Was going 70 most the way, and there were quite a few hills.
Fixing some minor and not so minor things so I'll see what I get afterwards. If I don't get any better milage, that's ok. The high idle drove me nuts and the leaks and other issues I posted here had to be fixed anyways. Hope to be running in a week or so.
-Adam
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
Re: Samurai MPG
« Reply #3 on: November 20, 2006, 08:37:18 PM »
18 or so on Highway -- I can pretend that its 20 if I don't adjust for the gears.
87 Samurai
Offline trckdtrak01
  • 17
  • Got Flex?
Re: Samurai MPG
« Reply #4 on: November 20, 2006, 10:20:50 PM »
Hey guys,
Just a heads up on gear for your sams. Calmini has everything you need to up the balls on your rigs. Starting with a single barrel/dual stage high performance carb made by Weber starting at 300 or so. U want it? They got it. Heres the link. Just to give ya an idea. I know a guy that got a sam that had over 7500 invested into the rig from calmini and petroworks. we got it for around 4000 even.  A good set up would be starting with the Carb, a set of Headers, and 2 1/2 exhaust. The carb removes all of that wiring, the stock restrictive air box. and much more. Basically what im getting at is if you want the mpg increase, and horse power. Calmini has everything u need.
http://www.puresuzuki.com/samurai2.htm
2001 Tracker
Engine: 2.0 Ltr 16 V DOHC
Transmission: Stock
Shoes: 205/70/15 Goodyear Assurance on 8" uniques
Audio: Pioneer 3wy 6x9's/stock fronts Interior Stock
Offline Amilla
  • 1076
Re: Samurai MPG
« Reply #5 on: November 21, 2006, 08:07:28 AM »
thanks for all the info about your rigs.
i was aware of all the calmini upgrades such as exhaust, carb, cam, header all the stuff that, but thanks anyway.
thanks again
Millski
Offline mineisbroke
  • 134
  • yip
Re: Samurai MPG
« Reply #6 on: November 21, 2006, 09:06:21 PM »
20mpg and i believe everything is workink properly . every tank is 20mpg dosent seem to matter where i go or it i tow my quads behind it it gets 20 , i wished for 30 but still only 20 ;D
Offline daddyizzle
  • 728
Re: Samurai MPG
« Reply #7 on: November 22, 2006, 05:44:59 AM »
????????????20???????????
with what carb and what tires? and what engine? That sounds way too low.
-Adam
Offline mineisbroke
  • 134
  • yip
Re: Samurai MPG
« Reply #8 on: November 22, 2006, 09:21:34 AM »
all stock
Offline DanielW
  • 15
Re: Samurai MPG
« Reply #9 on: November 22, 2006, 10:18:57 AM »
When I first got my 86 I was getting 29.2mpg every 200 miles ( my fuel gauge only reads when it wants to so I only go 200miles and calculate milage with what a fillup takes)
then it slowly went down to 26, now the last tank was at 20 but i've got some carb issues.
Offline daddyizzle
  • 728
Re: Samurai MPG
« Reply #10 on: November 22, 2006, 12:49:25 PM »
Assuming you have the stock carb and 1.3, maybe you need to clean your carb really good and check the emission components. Maybe it's dumping gas and needs a rebuild. Out of time? valve clearance? Could be alot of things. I'm no expert on this, but do the math.  I would think that getting this fixed would have to pay for itself.
-Adam
Offline truckasaurus44
  • 265
  • I'm a new world Samurai & a Redneck nonetheless!
Re: Samurai MPG
« Reply #11 on: November 22, 2006, 01:04:44 PM »
Also could be a clogged CAT.  My friend had the same depreciation in milage until he replaced the exhaust w/ CAT and he was back close to 30mpg.  A good tune-up, including air filter, valve adjustment and fresh timing belt will go a LONG way towards getting you more MPG
Offline daddyizzle
  • 728
Re: Samurai MPG
« Reply #12 on: November 22, 2006, 03:28:35 PM »
The lesson being to monitor your gas milage. A gradual drop or a sudden drop, either way, is always a good indicator that something isn't quiet right. Maybe even the only way to tell. Could be something as simple as an emission hose disconnected. If you're lucky.
I had a clogged cat on a nissan quest. I never noticed a milage drop prior but my wife said it had been steady. In the end, it would hardly climb a hill, and wouldn't hold 60 on the highway. I took it off and hollowed it out. Made the van a little louder but I didn't have the money for a new one.
The muffler shop even tested it and said it was good. The dealer said it was something else and charged me 250.00 + in diagnostics. I went with my gut and removed the catalytic and drove it breifly. Loud but fast. Risky on the valves too. I disputed the charge and got my money back. A total cost of time, frustration and gas.
-Adam
Offline Vagabond
  • 95
Re: Samurai MPG
« Reply #13 on: November 22, 2006, 08:26:41 PM »
As if any of us have an accurate odometer...
[/url]
