flat towing and calmini lift
  • 1732 Views
Offline tipover
  • 422
« on: November 20, 2006, 04:06:08 PM »
For you 3" calmini suspension lift owners, can you flat tow your rig?  I ask because my Sidekick is a dingy for my motorhome.  I flat tow with four on the ground and i have to put the t-case in nuetral which causes the front drive line to spin.  I have been doing it for years with out issues.
Obviously i tow it on the highway at 70 plus MPH and because the kit changes the angle of the u joint at the front diff, I wonder if there will be a vibration when I tow.
If it has a vibration, the sidekick would be useless to me cause i would just trailer my bad ass samurai.
Any comments?
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline Vagabond
  • 95
Re: flat towing and calmini lift
« Reply #1 on: November 22, 2006, 09:38:46 PM »
Do you have the transmission in gear when you tow?
[/url]
Offline tipover
  • 422
« Reply #2 on: November 22, 2006, 10:25:28 PM »
yes per the owners manual.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #3 on: November 23, 2006, 06:02:49 AM »
You can tow it, no problem.  I've had the the calimini 3 + 3 for 4 years and have not had a problem.  2 years ago I went to an anvil with toy axils and had to do the Mike H. widining.  Still no problems.
Also, I've driven with the hubs locked in going place to place to wheel.  Also no problems running at higher speeds.
Eric
32 MTR's Warn 8000i
Offline tipover
  • 422
« Reply #4 on: November 23, 2006, 09:21:59 PM »
thanks for the information.
