F150 wheels and tires.
  • 5 Replies
  • 2270 Views
Offline hickwheeler
  • 39
« on: November 22, 2006, 04:56:32 PM »
anyone know the mods needed to fit factory ford rims on trackers? anyone know ruffly the backspacing on most of them like between _" - _".
Re: F150 wheels and tires.
« Reply #1 on: November 22, 2006, 05:47:38 PM »
Most (I think all) stock ford Pick wheels will have the center too small for the Kicks Hub.
But aftermarket ford wheels will be fine cause most the holes are bigger.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: November 22, 2006, 06:51:59 PM »
I think this is only the case with ford 2wd wheels. The 4wd wheels are the right size hub hole.  I was told the wheels I bought were ford wheels, and they were fine. 3.5" backspacing.
Offline hickwheeler
  • 39
« Reply #3 on: November 23, 2006, 07:47:35 PM »
Really, no mods needed and 3.5" backspacing thats perfect, I can just get a set of stock ford wheels and tires and that will be an upgrade, thanks alot!
Offline lavigeboy27
  • 84
« Reply #4 on: November 26, 2006, 08:23:48 AM »
I bought a set of stock bronco wheels that were on a Sammy. They should fit fine.
Offline stosh22
  • 16
« Reply #5 on: November 26, 2006, 06:42:55 PM »
I went the a wrecker here to look at some Ford 8-Spoke rims and the hole pattern was correct but the centers were too small.
They also had a set of 4 8-spoke ford rims and they had the correct center.
So, as Hotrod said, some may have a slightly smaller center so you have to watch.
1992 Suzuki Sidekick 2dr 1.6l 8v, 3" Body Lift, 2.5" RRO Lift, 31 x 10.50 Pro Comp Mud Terrains mounted on 15 x 7 3" bs rims from RRO.  Thorley Header, K & N Filter.  Lifted Gas tank.
