Steering needs to come off
  • 1390 Views
Offline suzi_n_sammy
  • 184
  • Rock the Sam
« on: January 12, 2005, 05:13:47 PM »
alright im doing a yota axle swap and i took the rear end out today and  when i got to the front i got everything off except steering on the lower steering i already removed the cotter pin and took the nut off and i tried hitting it with some WD-40 and a mallet but to no avail and i dont want to brute force this thing if im not doing it right.
You can take the Sammy off the trail, but you cant take the trail out of the Sammy.
Re: Steering needs to come off
« Reply #1 on: January 12, 2005, 05:35:15 PM »
Whack the Pitman Arm (on the steering box)
with a 16 Oz steel hammer, not super hard,
just good solid hits, about 6 to 20 whacks and
the arm will fall off
Now you can get a propper Ball Joint press
and take it all apart if needed
The smaller Ball Joints come apart the same way
if you can get a solid hit on them
