how big of tires
  • 10 Replies
  • 3246 Views
Offline sidekick 4x4
  • 97
  • sidekick
how big of tires
« on: November 29, 2006, 02:21:16 PM »
does any one know how big or tires i could run on a stock sidekick with out any rubbing
1990 sidekick,snorkel, 2.5" coil spacers, procomp shocks and strut extenders, 3" calmini body lift, 30" A/T,CHEERY BOMB MUFFLER
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: how big of tires
« Reply #1 on: November 29, 2006, 02:24:11 PM »
Should be a thread around here somewhere on this. But it really depends on your ride height. 235/75/15 or 235/70/16 is the largest that most people on here post as being on stock rigs. Take your rig into a tire dealer usually they can mount up a tire or two for you to look at. :)
Mean Green Wheeling Machine
  • 97
  • sidekick
« Reply #2 on: November 29, 2006, 06:07:38 PM »
ok thanks and my sidekick is stock so its not lifted
Offline kirknd4spd
  • 333
« Reply #3 on: November 29, 2006, 09:33:42 PM »
yeah, 235/75R15 is about the biggest you can fit without rubbing on a 2 door. on a 4 door, they might rub a little in the rear. hope that helps
  • 97
  • sidekick
« Reply #4 on: November 30, 2006, 04:17:01 PM »
yea that helps but are sure because right now i have 26" tires on my 2 door sidekick and it looks like i could fit alot bigger tires than a 28"
Offline JayN
  • 220
« Reply #5 on: November 30, 2006, 06:15:20 PM »
depends on how much cutting you are willing to do as well. >:D
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
Offline olija
  • 770
    • Check out my cardomain
« Reply #6 on: November 30, 2006, 08:45:16 PM »
235/75 is closer to 29" than 28. It's 28.8". Just remember, if this isn't a true poseur-mobile you want it to be able to flex some too. I'm lifting mine 1.5" and putting on 235/75's, but mainly because it was a great deal ($100 for 4 tires) and I didn't want any rubbing or trimming.
Offline kirknd4spd
  • 333
« Reply #7 on: November 30, 2006, 09:01:37 PM »
well, on mine, the 235's only rubbed the front fenders sometimes at full lock while flexing with no lift.
« Reply #8 on: December 18, 2006, 03:26:43 PM »
I have 30X9.50"s On my stock 91 Kick on a 15x7 Rim with not problems
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #9 on: December 19, 2006, 01:38:30 PM »
Got pics of that? lock to lock?
I had worn 30's on 15x7's with 1" coil spacers and mine rubbed in the rear of the front well, I had to trim.  They also touched the top of the rear fender when flexed.
However, I do have a friend using 30's on stock 5.5" rims with no lift, and mild rubbing, but the 7" rim changes things, also some 30" tires really only measure 29"
Offline urbanwheeler
  • 696
« Reply #10 on: December 19, 2006, 01:46:38 PM »
I put some 225/75R15s on mine and they work great(especially for being WAL MART tires). The tires I got are the Uniroyal Liberator A/Ts and they costed about $62 a piece (compared to the 80 a piece for the Yokohama Geolandar A/Ts I was going to get).
