cj axles and leafs in a swb tracker
  • 1766 Views
Offline TrAkLsI
  • 61
« on: November 30, 2006, 07:12:24 PM »
Anyboby done this?  What's the good and bad about this.  Thanks,
Offline kirknd4spd
  • 333
Re: cj axles and leafs in a swb tracker
« Reply #1 on: November 30, 2006, 10:09:49 PM »
good (maybe): straight front axle
bad: the axles are from a J**P!!
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: December 01, 2006, 07:53:59 PM »
Depends on the gearing you can get, the old CJ's had low r&p's, I'm not sure if you'll be able to get anything above 4:xx. You also need to look at axle widths, and the brakes - a neighbour of mine had an old CJ, and I'm sure it had drum brakes.
Offline TrAkLsI
  • 61
« Reply #3 on: December 01, 2006, 11:03:43 PM »
Uncivilized, do you know about installation, is it the same as toyota's.  I can get some cj's for cheap or should I look for some toy's.   Thanks alot,
