Tracker trans/sammy T case
  • 1996 Views
Offline aabest
« on: November 30, 2006, 08:24:28 PM »
I want max MPG out of my Tracker, but still want the 4x4.
OK......here's what I'm thinking.
I will replace my 4x4 auto tranny w/ a Tracker auto OD tranny and use a Samurai transfer case.
Has anybody done this? Any input either positive or negative?
Any better ideas?
Does anybody know the ratios of the Samurai T case and the Tracker T case in 4wd low?
Regards, Karl at http://aabestco.com/tracker.htm
Offline chet
  • 556
  • Zuki time!
Re: Tracker trans/sammy T case
« Reply #1 on: November 30, 2006, 09:05:23 PM »
how is this going to help your MPG. the sammy case has high range reduction so I can't see it helping.
Offline kirknd4spd
  • 333
« Reply #2 on: November 30, 2006, 10:06:15 PM »
yeah, i dont tink that will help. if you want god gas mileage, get a geo metro. or an older VW with a turbo diesel.
« Reply #3 on: December 03, 2006, 04:14:41 PM »
Any better ideas?
How about just swapping the 4 speed auto and driveshafts in, from the tracker the 4 speed came out of.  IIRC, the 4 speed is longer, so it will require you use the driveshafts that came out of the 4 speed auto tracker.  Also, IIRC, the tcase from certain year 3 speeds will work with the 4 speed tranny and driveshafts.
Tcase ratios.....
tracker low 1.82:1
tracker high 1:1
samurai low 2.268:1
samurai high 1.409:1
