grille removal?
  • 4424 Views
Offline thrash
  • 54
  • thrash thrash thrash
grille removal?
« on: December 02, 2006, 11:57:41 PM »
hey there
can any one out there run down some steps on removing the pastic grille ?
thanks
jeeps are like tampons
every pussy needs one
http://www.cardomain.com/ride/2295298
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
Re: grille removal?
« Reply #1 on: December 03, 2006, 07:24:03 AM »
See the pic I've attached to this message.  Carefully remove the tabs on the top of the grill (the big red oval in my pic).  You'll need to have the hood up.  If you break them, you'll have to pick up some universal type ones at an auto parts store.  Then, I've indicated the other grill connection points with red circles.  Start with the center and work your way out.  Firmly grab the grill near a tab, and *very carefully* pull.  You'll feel it start to work loose as the plastic tabs pull out of their holes.  I've done this at least ten times to recharge my AC system without breaking anything.  Still, you must be careful.  Good luck!
« Last Edit: December 03, 2006, 07:26:40 AM by Davyboy »
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
Offline thrash
  • 54
Re: grille removal?
« Reply #2 on: December 03, 2006, 10:52:38 AM »
have you attached the wrong picture?
Offline atc_gv
  • 76
Re: grille removal?
« Reply #3 on: December 03, 2006, 11:38:02 AM »
That is the right picture, he is showing you the location of the tabs. The ones attached to the bumper can be difficult and you cant see them. I purchased some of the snaps from an auto zone, the ones for GM vehicles fit perfect. It is always good to have extra tabs because I break them all the damn time. Good luck.
Offline thrash
  • 54
Re: grille removal?
« Reply #4 on: December 03, 2006, 11:54:30 AM »
ha right
i didnt have my glasses on so i didnt see the markings he made on the picture
my fault :P
thanks for the help
Offline Davyboy
  • 252
Re: grille removal?
« Reply #5 on: December 03, 2006, 12:15:17 PM »
Yeah....sorry 'bout that.  The little red circles in the pic aren't as noticeable as I hoped they would be.  Good luck.
Offline Maroon Monsoon
  • 876
Re: grille removal?
« Reply #6 on: December 03, 2006, 03:12:44 PM »
wicked, all the info I need, thanks for making this post Thrashmiester
