4DR Brake Upgrade Prices
  • 9 Replies
  • 3608 Views
Offline fullsink18
  • 250
  • Wheel Me!
« on: December 04, 2006, 10:57:41 AM »
I was wondering how much it would cost to do the swap.  I was looking at partsamerica.com which is advanced auto parts online site and calipers were around 75 dollars each for remanufactured and loaded.  Just wandering if that is a good price or if anyone know where you can get them cheaper.
Thanks.
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Offline CJ11
  • 157
  • 95 SIDEKICK ON 31'S
Re: 4DR Brake Upgrade Prices
« Reply #1 on: December 04, 2006, 02:15:57 PM »
junkyard did mine for about $40.
Offline CJ11
  • 157
« Reply #2 on: December 04, 2006, 02:59:20 PM »
well more like $60 . 2 rotors at advanced 18.99 ea  2 junkyard calipers and pads $20 for the both pads were like new.  The only problem with the swap dry roads it stops on a dime. Wet roads they lock up to easy. slide like hell kind of nervous to drive in the snow the littlest bit of pressure on the peddle and it seems to slide on wet roads that is. Maybe thats why I smashed int that ford acouple of months ago. QAny one else have the same thing..
« Reply #3 on: December 05, 2006, 05:27:19 AM »
If you've only done the fronts then you've messed up the brake balance. You should have got the rears at the same time.
Offline CJ11
  • 157
« Reply #4 on: December 05, 2006, 02:47:22 PM »
From what i was told with the rear I would have needed the master to did not want do that much work I thought you could just do the fronts and be fine.  That sucks is there any way to fix the problem with out using the 4 door backs. Or should I just go back to my 2 door brakes.  Please help.
Offline stock93tracker
  • 309
« Reply #5 on: December 05, 2006, 03:07:28 PM »
i did the swap and i didnt notice any imbalance in front/rear braking...  What kind of problems could be incured from this?  I replaced the rear brakes with 2 dr rear breaks a week after the front swap, it seems to work fine as off now..
My rotors were 23.99 a piece from NAPA, 88 bucks for the calipers from AutoZone I beleive.
93 Geo Tracker
-2" Lift
« Reply #6 on: December 06, 2006, 04:56:39 AM »
The first thing that you should do is to strip the rears and make sure everything there is good and works OK. Does the 95 have the load proportioning valve, the one with the spring down to the axle?
There are two sizes of master cylinder, the 4dr does have the larger one but its probably not essential, you'd just get a bit more pedal travel.
If the brakes aren't safe in the wet then the 2 dr calipers would be a better option.
Offline Rascal
« Reply #7 on: December 06, 2006, 06:45:54 PM »
Did this swap in the spring haven't had anyproblems .Fine in rain ,gravel roads ,even the ten inches of snow and ice that we just got last weekend
Offline Rascal
« Reply #8 on: December 06, 2006, 06:52:37 PM »
 ::) oops forgot the price 100.00 junk yard every thing from the spindel out  ,brackets ,calipers ,rotors ,lockout hubs and hubs. new calipers around thirty five or so, turned rotors 10.00 each .And about four hour labor (mine) . Got the backing plates too didn't need them fit the two door no problem.
Offline CJ11
  • 157
« Reply #9 on: December 24, 2006, 07:18:45 PM »
found my problem was not the balance issue. It was leaking back wheel cylinders the fluid was pouring out like crazy. That was why I was addig fluid every couple of days. Stops on a dime now thanks for all tha help.....
