mystery button
  • 9 Replies
  • 2730 Views
Offline Twan013
  • 98
  • meh.
mystery button
« on: December 04, 2006, 08:38:27 PM »
hey guys, long time no post for me!    anyway, i bought a cb radio the other day, and when i was trying to find a way to run the wires, i found a tiny little button hanging in the tracker..  it looks kind of like a basic on/off pushbutton switch, but i have no idea what it goes to... its really too small to be anything aftermarket (like a set of foglights from the previous owner...)  and it doesn't seem like it would be the button for the domelight (when the door opens and closes)...  because its not in the door area... i mean, it could have been pushed or pulled out by accident (remember i treat this thing rough as far as driving it goes).. and i can't tell if its the domelight because that bulb has been missing ever since i bought the thing, and i just haven't felt like replacing it... anyway, can you guys see if you can find something on your vehicles that resembles my description?  by the way, i have a 96 tracker 2door soft top...  if i'm not mistaken, there's an engine code reset button in the engine bay of the samurai somewhere... maybe that's what this button is, and just put in a different location
Re: mystery button
« Reply #1 on: December 04, 2006, 09:08:43 PM »
There is a service engine light reset switch located behind the speaker to the left of the steering wheel.  Its pretty small like you are describing.
Offline greenmachine
  • 23
Re: mystery button
« Reply #2 on: December 04, 2006, 09:42:18 PM »
In my Haynes book it talks about that elusive switch. It resets the check engine light. I never found mine on my 95jx. I found that pulling the fuse works fine.
Offline Jarrodl
  • 40
  • She thinks my TRACKERS sexy!
Re: mystery button
« Reply #3 on: December 05, 2006, 12:53:35 PM »
where did you find the button? I found the reset behind the speaker in my 90 tracker, but I can't find in in my 96.
96 Tracker 4x4 Automatic 2dr Soft Top
Re: mystery button
« Reply #4 on: December 05, 2006, 08:37:04 PM »
heres one pic (from somebody) of the reset switvh location.
Nice pic. ;D
Offline Twan013
  • 98
  • meh.
Re: mystery button
« Reply #5 on: December 06, 2006, 06:59:43 PM »
jarrod, i found mine in front of the driver's door, in amongst all the wires coming from the fender well to up under the dash... and hotrod, that looks nothing like mine, so maybe i just found something totally different...  mine is black and round, maybe a quarter inch total size... the button itself is only the size of the tip of a ball point pen
Offline Carnage
  • 2453
Re: mystery button
« Reply #6 on: December 06, 2006, 09:20:22 PM »
hotrod... is that at the bottom of the steering column or by the speaker?
twan... can you post a picture?
Re: mystery button
« Reply #7 on: December 06, 2006, 10:39:35 PM »
I think that is through the speaker cover hole being removed.
Someone else posted the pic a while ago
Re: mystery button
« Reply #8 on: December 07, 2006, 09:15:20 AM »
The pic posted earlier was taken from below the steering column.
Could the switch you found be the dome light switch that is normally located between the door and the body (could it have been pulled through to the inside of the vehicle)?
Offline Amilla
  • 1076
Re: mystery button
« Reply #9 on: December 07, 2006, 09:34:07 AM »
I just found mine last night, its just right of the steering column, but lucky for me, the person who owned the samurai befor me didnt like the check engine light.  So when it started spitting codes and staying on. He couldnt figure it out so he first put electric tape where the check engine light shows, then he cut the wires that go into the gauge cluster...
you can see the nice 3 wires on my post "3 little wires"
Amilla
