89 Sidekick running RICH
  • 2134 Views
Offline tonyman246
  • 58
« on: December 04, 2006, 09:20:57 PM »
My 89 Sidekick 8v that I recently installed myself is running extremely rich. It blows black smoke even while idling. It runs great at any rpm and has between 140-150psi in every cylinder.
I’m almost 100% sure it’s a vacuum problem. I put the lines back together as I thought they should be, but I need a picture or a diagram of how they should be.
DOES ANYONE HAVE A PICTURE OR A DIAGRAM OF THE VACUUM LINES??
1991 Geo Tracker 33" super swampers + 4" lift + minor fender trimming + locker = unstoppable!
Offline tonyman246
  • 58
Re: 89 Sidekick running RICH
« Reply #1 on: December 05, 2006, 09:17:42 AM »
come on, nobody knows?
« Reply #2 on: December 05, 2006, 10:38:11 AM »
89 is an odd one, the EFI is a bit different from the later models. there are a few people that have them, you may just need to be a bit patient.
When you did the swap did you reuse all the 89 EFI parts? Black smoke implies very rich, as if the injector is stuck open. If you have a later TBI then that could be your problem, the TPS is different and the TPS shares the same connector as the injector.
« Last Edit: December 05, 2006, 10:42:27 AM by Rhinoman »
