valve adjustment
  • 5946 Views
Offline boscosfire
  • 14
  • Sammy Crazy
valve adjustment
« on: December 08, 2006, 09:07:26 AM »
I need to set my valves on my sammy it has a 1.3 in it and I need to know what the valve lash is and what procedure it is done in . I cant find anything on the net if anybody could send me a link I would appreciate it.
Offline Amilla
  • 1076
Re: valve adjustment
« Reply #1 on: December 08, 2006, 09:18:59 AM »
i can do as good as clearances
8 valve engine
Intake:
Cold....................0.005 to 0.007 inch
Hot......................0.009 to0.011 inch
Exhaust:
Cold.....................0.006 to 0.008 inch
Hot.......................0.010 to 0.012 inch
just valve clearances
Amilla
« Reply #2 on: December 08, 2006, 01:35:57 PM »
Sammy FSM available here:
http://www.suzukiinfo.com
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: December 08, 2006, 08:33:40 PM »
The FSM is also at:
http://www.acksfaq.com
Do a search for fsm
There you will find the '88 FSM in three pdf files with detailed instructions on how to position the cam for intake and exhaust valve lash setting along with the lash values that amilla posted above.
There are almost 300 other searchable links to zukin' info for you, too!
Hope this helps!
Ack
