Disconnecting ABS.. how?!?!
  • 4145 Views
« on: December 11, 2006, 11:59:36 AM »
Yes, I want to Disconnect my ABS.
Do you guys have any ideas?
I fkn hate it! Its just plain dangoerus when offroading in the snow! One time it was the main reason I went backwards over a HUGE rock..
(Here´s a picture of the stone.. I went over it backwards and all the freaking brakes did was a drum solo! In the picture we have already pulled the stone a little bit, the car sat on the front drive shaft when it finally stopped)
http://img335.imageshack.us/my.php?image=image230dp9.jpg
« Last Edit: December 11, 2006, 12:01:30 PM by Icelandic »
Offline blacknight
  • 987
    • Gonzookin
Re: Disconnecting ABS.. how?!?!
« Reply #1 on: December 11, 2006, 12:39:08 PM »
Pull the fuse or add a switch some place that will trip an ABS light to come on which should  kill it all so.
George
« Last Edit: December 11, 2006, 07:06:21 PM by blacknight »
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #2 on: December 11, 2006, 01:33:52 PM »
just as the 2WD LO "conversion" then.. :D
i like that one too.
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
« Reply #3 on: December 11, 2006, 05:53:19 PM »
I've thought of that as well.  Is the fuse linked to any other control, or is it just dedicated to the ABS?  Thanks.
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
Offline IanL
  • 466
« Reply #4 on: December 12, 2006, 01:30:03 AM »
The ABS Control Module is supplied by two fuses:
No 21  IG METER 20 A - Wire is Black/white stripe
No 2  Main Fuse 50A   - 2 wires Black/blue stripe
I think the Black/white may just be power for the indicator, so you probably need to interrupt the Black/blue.  Note that the supply splits into two wires into the module - I don't know where the split is in the harness.
The module is the large unit under the hood.
Let us know how you get on!
« Last Edit: December 12, 2006, 01:39:49 AM by IanL »
« Reply #5 on: December 12, 2006, 04:47:27 PM »
I just took the Main fuse 50A out and it works great..
The indicator doesnt bother me at all :D
Thanks guys :)
Offline mrleft.hk
  • 17
« Reply #6 on: December 14, 2006, 05:39:11 PM »
I'm lazy to wiring, just unplug one of the  ABS connectors in engine room. Usually I do the right(black) one (more space to do it, mine is RHD GV). It's better to switch off the engine when plug or unplug it, then restart the engine will reset the computer.
mrleft
2002 Grand Vitara 2.0 5dr
1988 Samurai (Retired)
1999 Jimny
