New mods: rear bumper and shock adaptor
  • 3551 Views
Offline wiretap_MD
  • 73
  • Where the Road Ends...Life Begins!
« on: December 17, 2006, 02:36:44 AM »
Kindly refer to the links below...
Rear shock adaptor:  http://4x4ph.com/forum/index.php?showtopic=8193
Rear bumper:  http://4x4ph.com/forum/index.php?showtopic=8033
Thanks for visiting
'01 Sidekick: OME-Calmini Hybrid Suspension, 1.5-inch spacers, Bilstein 5125 re shocks, 2-inch bodylift, 30x9.5 BFG, Safari Snorkel, ARB bumper, Custom rear bumpe
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: New mods: rear bumper and shock adaptor
« Reply #1 on: December 17, 2006, 04:00:13 AM »
Sorry, but I get an error trying to access those pages having to do with access priveledges...
Ack
Offline wiretap_MD
  • 73
« Reply #2 on: December 17, 2006, 07:39:35 AM »
I needed to replace my rear shocks with something firmer than the Doeschtech prerunner shocks that came with the Calmini kit. With a full extension length of 22 inches, options were either shocks from a Crown Victoria or an E150 which had the same length. OME and Bilstein stock shocks were still too short to serve as a replacement.
A friend recommended the Bilstein 5125 offroad series which had the full extension length I wanted. The only problem was that it used an eye-type mounting for both ends.
An adaptor was then fabricated:
Ronald of 199 recommended the Bilstein 5125 offroad series which had the full extension length I wanted. The only problem was that it used an eye-type mounting for both ends.
It was an adaptor to convert the upper shock mounting to an eye-type. With this, it opens up the Vitara to more shock options than before.
Here's a picture comparing side by side my old doeschtech calmini shock with the Bilstein 5125:
Pictures of the adaptor mounted:
Shock boots were removed to prevent dirt accumulation. Here are the final pics of the adaptor and Bilsteins installed:
On road, the Bilstein 5125s ride waaaaay better than my former shock. Firmer, better dampening, with less bounce and sway.
Offline wiretap_MD
  • 73
« Reply #3 on: December 17, 2006, 08:47:32 AM »
Rear bumper with integrated Class 2 hitch receiver
« Reply #4 on: December 17, 2006, 09:11:13 AM »
Good looking rear bumper.
Teh one thing I do see is that running the other eyelites on the shocks
is they seem to shorten your shocks reach by 2 more inches.
But I like being able to run the shock bodys upside down.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #5 on: December 17, 2006, 12:24:16 PM »
It looks to me that with those shocks and the pin-eye adapter that the down travel available may be a touch more than the Calmini allows but without the specs on both shocks I can't tell if it makes any difference to the uptravel. I too have been looking at swapping to eye-eye shocks due to the larger range of options available.
That's a nice job with the rear bumper although I think a bit more angle on it by the rear wheelarch to open it up even more would have nice. A swingaway wheel carrier would have been nice too ... get that weight of the door.
Offline wiretap_MD
  • 73
« Reply #6 on: December 17, 2006, 05:33:03 PM »
Yup I agree but since I have a 1.5 inch coil spacer, that would compensate for it.
