wheel ?
  • 1820 Views
Offline brace
  • 264
  • I built it; I break it; I fix it.
wheel ?
« on: January 10, 2005, 02:20:41 AM »
I thought all 96 and below F150 rims were interchangeable w/ zuks.  My buddy has some rims off a '91 f150 and they don't fit his tintop.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Crabzuki
Re: wheel ?
« Reply #1 on: January 10, 2005, 02:58:04 AM »
The bolt pattern is the same except for the center cut-out for the cap. Now on the 1990 F-150 the center cap opening will fit fine without the need of grinding the center hole to fit over the Zuki hub. ~CZ
Offline tOnKa TrAcKeR
  • 264
  • support our troops
    • Cardomain site
Re: wheel ?
« Reply #2 on: January 10, 2005, 03:11:31 AM »
MY Tracker has rims off of a 79 Bronco  but heres the info i found in my parts book:
Samurai's bolt pattern is 5x5.5
other vehicles with the same bolt pattern:
other zukis (track/kick, x90) obviously
66-96 Ford F-150,Bronco
74-2002 Dodge/Plymouth Full Size Trucks/Vans & RamCharger/Trailduster.
94-up Kia Sportage
Now thats just the bolt pattern you also have to look at the center circle i had som rims off of a 1974 F-100 and it wouldnt fit on my tracker because the center hole would not fit around the front hubs.  hope this helps
