whats the cheapest and easiest way to lift my tracker?
  • 4229 Views
Offline westvilleguy
  • 53
« on: December 28, 2006, 10:46:59 AM »
looking for a cheap way to lift my tracker thinking either a body lift or coil spacers how much are the coil spacers(canadian) and how hard to install? and what would be easier a 2" or 3 " body lift i know when i put the 3" in my old jimmy had to extend quite a bit of stuff and move some stuff around in the engine bay and what are body lifts worth for these (canadian) i have 205's on it for the winter and 235's on one of my other trackers that will be going on this one and will probably stay with this size unless i could get 31's to fit how much would i have to lift it for 31's?
89 chev tracker 4x4 tintop
91 gmc tracker 4x4 tintop
93 geo tracker 4x4 tin top
94 geo tracker 4x4 hard and soft top
Re: whats the cheapest and easiest way to lift my tracker?
« Reply #1 on: December 28, 2006, 11:35:37 AM »
If you can find them, the coil springs from a GV add real lift.
Offline tracker975
  • 9
« Reply #2 on: December 28, 2006, 03:18:21 PM »
How much more lift do they give....is it comparable to the spacer...body lift combo.
Offline WorkInProgress91
  • 31 gets it done
« Reply #3 on: December 28, 2006, 03:51:22 PM »
I would say that the easiest way to lift it would be coil spacers.  With a body lift, you are going to encounter issues with your shifters, and I ended up having to rig myself up a new center console, and modify the hole in the floor for the t-case lever.   To fit 31's with just a 2'' lift though, you may have to do a bit of trimming.  I ran my 31x 9.50's  on 15x7 rims for a couple of months with just a 2'' b/l, and the only thing i did was hammer the firewall a bit.
91 sidekick
2'' B/L, 2'' coil spacers
31'' swampers
winch
custom bumper tank lift camouflage duct tape
