Flowed an intake
  • 2154 Views
PSYKOCHI
Flowed an intake
« on: December 31, 2006, 06:10:59 PM »
 ;D  Has anyone ever flowed a 1.3L & a 1.6L intake manifold?
Re: Flowed an intake
« Reply #1 on: December 31, 2006, 10:12:18 PM »
Ya, every time I step on the gas  ;D   the dirt going through it bores it out and polish's it also, a little slow but it's cheap  ;D
« Reply #2 on: January 01, 2007, 09:20:59 AM »
I fitted the 413 intake to the 1.6 in the pickup. I have matched the ports but I didn't spend a long time on it because I intend to fit the 1.6 TBI setup in the spring. I didn't use any specialist tools just an electric drill, flexidrive and a small cutting tool.
1.3 manifold with 1.6 gasket
The holes in the 1.6 gasket were a bit large so I opened out a 1.3 gasket to match the ports on the 1.6
The 1.3 manifold has a waterway running down one side of the port. Its at the top in this pic and has already been ground away a bit.
I ground the port down to the bottom of the casting mark around the waterway so the end result is a bit of a 'D' shape, it could probably do with a little filling on the carb side of the waterway to make it a less pronounced bump.
Like I said I didn't spend too long on the manifold. Apart from the problem with the waterway I don't think the manifold would be restrictive. If I had a spare manifold I would grind the waterway out to see just how thin the wall is in this area, maybe the port could be made round.
If I wasn't going TBI I would stick a 38/38 DGAS Weber on there, its a pretty common carb over here and I reckon it would give a good power boost.
« Last Edit: January 01, 2007, 09:29:41 AM by Rhinoman »
PSYKOCHI
« Reply #3 on: January 01, 2007, 03:57:00 PM »
 ;D  Thanks Rhinoman -- GREAT info -- I am trying to find an extra 1.3L manifold and your tricks.
Offline ROSS
  • 1412
« Reply #4 on: January 01, 2007, 07:23:19 PM »
I ALWAYS THOUGHT IT WAS PORTING
