sami drivetrain vibration???
  • 22 Replies
  • 5920 Views
Offline blasted879
  • 21
« on: January 01, 2007, 01:34:43 PM »
ok wassup everybody, i'm new here, just picked up a 86 samurai, its got SPOA, 3 inch calmini springs, missing links from rocky-road, 4.16 t-case, 31 swamper ssr's, and i got a real bad vibration at a certain rpm, around 2-3 grand. after that it goes away but still can feel it a little... tried shimming and and its still there! any help would br appreciated!
4x4boyz.com
all the way from the 808 state!!!!
Offline ROSS
  • 1412
Re: sami drivetrain vibration???
« Reply #1 on: January 01, 2007, 02:45:22 PM »
make sure the drivelines are slipped together right.  line up the dots . gets most people
Offline blasted879
  • 21
« Reply #2 on: January 01, 2007, 03:17:10 PM »
oh didn't know there was dots!!!! its on the shaft right? gonna check it out now!
4x4boyz.com
Offline ROSS
  • 1412
« Reply #3 on: January 01, 2007, 04:43:33 PM »
pull it  apart.  on the end of spline shaft theres a punch mark on the end. the receiving end pullthe boot off the other punch mark is there
                                                            Ross
Offline blasted879
  • 21
« Reply #4 on: January 01, 2007, 06:28:22 PM »
ok i checked and is all good! i even swapped it out with another drive shaft and the vibration is still there... >:(  whats the pinion angle supposed to be at?
4x4boyz.com
Offline ROSS
  • 1412
« Reply #5 on: January 01, 2007, 07:02:33 PM »
what about the intermediate driveline between the tranny and t-case
Offline blasted879
  • 21
« Reply #6 on: January 01, 2007, 07:11:43 PM »
hmmm never checked that? gonna check right now!
4x4boyz.com
Offline ROSS
  • 1412
« Reply #7 on: January 01, 2007, 07:19:15 PM »
i know someone who took his rear diff  apart looking for a vibration.  afterward found a bad u-joint in the intermediat shaft
Offline blasted879
  • 21
« Reply #8 on: January 01, 2007, 07:28:37 PM »
ok i just checked and the u-joints looks good...... but i found the trans mount is history! that should be the problem???? hopefully :-[
4x4boyz.com
Offline ROSS
  • 1412
« Reply #9 on: January 01, 2007, 07:30:47 PM »
maybe . good luck
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
« Reply #10 on: January 01, 2007, 07:47:18 PM »
   I don't know why no has mentioned this earlier, but I bet your too lifted for your driveline. A spoa and 3" lift springs is overkill for a stock sammy driveline and driveline working angle. Do you have a toyota cv or custom made cv shaft for the rear ? If you do not, you may think of upgrading to one and adjusting your pinion angle.
Offline W.O.T
  • 38
« Reply #11 on: January 01, 2007, 08:12:50 PM »
im having the same problem wih my samurai.  it started as a squeeking noise coming from somewhere near the transfer case.  it has gottten really bad and started vibrating big time.  im going to work on it tomorrow but i think its a worn out u joint on the shaft from the tranny.  thats where the sound seems to be coming from.  goodluck
Offline blasted879
  • 21
« Reply #12 on: January 01, 2007, 08:24:46 PM »
all my u-joints look ok???
hows does the pinion angle look????
4x4boyz.com
Offline flexmonger
  • 209
« Reply #13 on: January 02, 2007, 05:54:32 PM »
  Can you show me a pic of both the tcase and diff driveline angle at the same time?
Offline blasted879
  • 21
« Reply #14 on: January 02, 2007, 07:39:12 PM »
and you think the spring can have somrthing to it too? see the first leaf?
4x4boyz.com
