Tracker suspension kit - recommendations?
raztec
2
January 03, 2007, 05:40:15 PM »
HI guys,
I've got a '97 tracker which I use mainly for paragliding. This involves taking 4-5 passengers up steep mountain roads. I'm trying to beef it up a bit so it doesn't bottom out the suspension as much.
After some research on the internet I've decided the OME kit is the way to go + bigger tires.
Does anyone have any experience with this kit and any recommendations one way or the other compared to other kits? Also, any idea what size tires I can get away with after the kit is installed?
Thanks a bunch,
Raz
Mikerpm4x4
2875
12
Redline... all the time!
Re: Tracker suspension kit - recommendations?
January 03, 2007, 10:40:33 PM »
OME is a good kit. For what your looking to do with this rig I think its a good choice. Im not really sure what your question is though.
Mike
raztec
2
January 04, 2007, 02:00:49 AM »
Just wondering if anyone has this kit and compared it to others, like the Calmini?
Also, for those who do have the OME on their tracker/kick what size tires are you running without having to lift the body?
Thanks,
Raz
bentparts
4536
60
I'd rather be Blown AND Injected.
Reply #3 on:
January 04, 2007, 03:49:04 AM »
USe the search function, and you'll probably find many references to the 2.5" lift kit. You can get as much as a 225x15 under it without a body lift, should'nt have any problems.
Yankee-Tim
562
Reply #4 on:
January 04, 2007, 11:53:25 AM »
Blacknight has first hand experience with having both the OME and Calmini lifts on a GV (similar to a Kicker). Ask him for his thoughts.
kirknd4spd
333
Reply #5 on:
January 04, 2007, 09:08:09 PM »
i dont have experience with the OME kit, but ive heard that it is a good kit. with 2.5 inches of lift, you should be able to fit 30's, maybe 31's. i have 31's with my 3 inch Calmini lift.
