Valve Adjustment help....
  • 2066 Views
Offline Tattoo
  • 50
« on: January 03, 2007, 08:56:26 PM »
So, I have never done this before........   I have the FSM for an 88 Samurai and I
have been lacking power and as one more thing to check I am trying to see if the valves
need to be adjusted.  I pulled the valve cover and I can't get the tiniest feeler under any
of the adjustment screws......  intake or exhaust.  The manual just says to "check gap and
adjust as necessary."  Do I need to do anything to the cam position  or turn the engine over to a certain position to adjust them?  I hope this doesn't stupid,  cause I am at this stuff.   Help.
Thanks,
T
Offline chet
  • 556
  • Zuki time!
Re: Valve Adjustment help....
« Reply #1 on: January 04, 2007, 09:53:45 AM »
yes you need to put the motor at TDC on #1 cylinder and you do 4 valves there and then rotate it one rev and do the last 4 valves. can't remember the exact sequence. If you just try and do them at any position the valve may be open and it would severely screw up your adjustement. Get a haynes manual it tells exactly how to do it in there.
Offline Tattoo
  • 50
« Reply #2 on: January 04, 2007, 02:15:45 PM »
Thanks for the help.  I found it on I-zook this morning.
T
Offline Tattoo
  • 50
« Reply #3 on: January 04, 2007, 05:30:02 PM »
Any help on how I can turn the crank over to line-up the "T" on the timing wheel to
check my valve clearance??  I can turn it some but then it stops and I can't turn it over anymore?  I'm turning the belt in font to move it now......
Thanks,
T
Offline ROSS
  • 1412
« Reply #4 on: January 04, 2007, 06:13:16 PM »
pull the spark plugs it will turn over easy
Offline Tattoo
  • 50
« Reply #5 on: January 04, 2007, 07:48:47 PM »
Thanks dude, but I already did and it will only move a few inches..........
