Lock-Right locker troubles...
  • 2940 Views
Offline Zooki
  • 38
« on: January 04, 2007, 05:45:22 AM »
I just installed a Lock-Right locker in the rear of my '97 Sidekick Sport, and it's not acting quite right. It's a 1510 model, which Trail Tough assured me would work if I reused my old spider gear  & pinion shafts.  I notice that Trackers call for a 1512 model. What's different? When I turn sharply, such as pulling into of a driveway, or turning into a gas station, it groans loudly, and the whole vehicle shudders. This thing is Loud & scary! I know that Lock-Right recommends turning under throttle, but that's not always achievable. It feels like it's not unlocking, and I don't hear the "clicking" noise that it should have. I had a EZ Locker in a Samurai I used to own, and it never did this. It would just "click-click-click" when turning . This has me wondering if I'm going to bust an axle. Is this normal in an Automatic equipped vehicle?
Offline chet
  • 556
  • Zuki time!
Re: Lock-Right locker troubles...
« Reply #1 on: January 04, 2007, 09:01:21 AM »
uh a 1510 should not fit in a sidekick rear diff. you can use one with mods in the front diff but not the back. you are correct in it should be the 1512. thats what I have and it makes the click-click sound when turning with no load. recheck the product # and if its a 1510 get it out of there right away.
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
« Reply #2 on: January 04, 2007, 06:50:35 PM »
  A 1510 lockright will work in a kick rear diff. Owned my hybrid  rear axle for many years and have always used a 1510 lockright in it.  Maybe it was setup too tight?  Sometimes you need to use different sized shims on the spider gears and shave the center block.
Offline Zooki
  • 38
« Reply #3 on: January 05, 2007, 05:10:45 AM »
Yea, I talked to Brent at Trail Tough yesterday about it, and it sounds like I need to take one of the shims off of each side gear, and sand a little more off of the center block.  Anyway, he's a nice guy, super customer service. He told me everything I need to look at since the instructions leave a little to be desired as far as specifics. I'll tear into it tomorrow and see what the problem is. Thanks for the replies!
Offline RShrimp
  • 28
« Reply #4 on: January 05, 2007, 05:48:58 AM »
Dont they have a "go no-go" tool to check the clearance between the disks?
88.5 Samurai with spring over and 31,s
Americas Oil problem is simple. We just can't seem to check our oil.
The oil is in Texas and Alaska .... The DIP STICKS are in Washington!
