(Re) Spline axle shafts...
  • 2219 Views
Offline vitara-dave
  • 11
« on: January 05, 2007, 09:01:01 AM »
I want toe make a costum rear full floater axle and also a special front axle. Both have to be 26 splines to accept a rear sidekick diff. All the information about cutting splines can be usefull. Has anyone tried to resline an axle to 26 splines?
Offline tsleong
  • 66
  • I love zuk
Re: (Re) Spline axle shafts...
« Reply #1 on: January 05, 2007, 09:17:29 AM »
Axle cannot be resline. You got to made new custom axle shaft. I had a few custom ones made out of 4140 steel at a local machinist shop. Now I am trying to find a place to heat treat it.
Offline igofshn
« Reply #2 on: January 05, 2007, 09:48:22 AM »
I'm sure Currie, or Superior could make you some axles.
Offline vitara-dave
  • 11
« Reply #3 on: January 05, 2007, 10:28:58 AM »
I can respline the axle that I have for the front. I know that an axle is heat-treated but if I’m lucky I can cut true it. Otherwise the shafts have to be chilled first.
I found someone who can help me with the heat treatment.
Probably currie or superior can help me, but because I am from Belgium those axles that they make would be too expensive.
« Last Edit: January 05, 2007, 10:33:03 AM by vitara-dave »
Offline tipover
  • 422
« Reply #4 on: January 05, 2007, 10:28:36 PM »
dutchman in oregon resplined mine when i did it!  call them
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
