4 Speed Automatic problem
  • 1877 Views
Offline fgials
  • 80
  • Central Mississippi Suzuki Association
« on: January 07, 2007, 11:36:14 AM »
Well Joe S. just bought a 95 Sidekick and on his way home he is experiencing problems.  He said that while you get up to speed it the overdrive light will come on and the truck seems like it is goin into neutral and revs up to about 5000 rpm.  Then the light cuts off and the truck goes back to driving fine.  He said it started around 35-40 and now it is doing it sometimes in 60-65 range.  And the Overdrive putton doesn't work on the shifter.  And help would be appreciated!  thanks
Daniel
Quote from Joes S. when he got back in town:
thanks daniel. it seems to do it worse the warmer it gets. on the hour and a half drive home, it seemed to do it worse the closer to home we got...  it is like it is shifting but cant find the gear. do i need to look at the computer? or the solenoids inside the tranny? or is it the tranny itself?
also, i have access to a 95 tracker transmission computer that i can plug up to see if that may be the problem. where is the computer located, and would that tell me what i need to know?
thanks
joe
Offline Joe S.
  • 86
  • ZUKIWORLD Rocks!!
Re: 4 Speed Automatic problem
« Reply #1 on: January 07, 2007, 08:21:04 PM »
thanks daniel...
another thing. if i accelerate hard, it doesnt seem to do it as bad. it seems worse the slower i am going.  (like easy shifts)...
i am flustered...
Zuks are more than a hobby.
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« Reply #2 on: July 26, 2007, 02:48:08 PM »
The problem sounds similar to the one that I am having.  I just spent $275 to replace the TPS,  but that didn't fix it.  How hard and expensive  is it to replace the ransmission solenoid?
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Offline Joe S.
  • 86
  • ZUKIWORLD Rocks!!
« Reply #3 on: July 26, 2007, 03:05:21 PM »
my problem isnt like yours... so i can offer no help. mine ended up being a stripped wire that was grounding against the block, throwing the transmission and motor ECUs into a frenzy... got that fixed thanks to a mechanic's sharp eye, and havent had any more problems...
