New Member here need help with Samurai 1.6 engine swap
  • 1844 Views
Offline jrryrog
  • 1987 Samurai, 5" SPOA Lift, 31" mudder's
« on: January 07, 2007, 08:50:17 PM »
Hello, Good to see so many Suzuki people out there. I was hoping for some help with a 87 Samurai engine swap. Out with the old 1.3, and in with a brand new 1.6, 16 valve. The 1.6 is out of a 94 Sidekick. I know I need a plate for the bellhousing, where is a good place, besides Rockey Road Outfitters, I had a bad expereince with them, to get the swap kit. Also, the wiring, can I buy a already made wiring harness, or is it something, I'll be able to make myself??? My Samurai has a 5" SPOA lift. I have the 1994 Sidekick I got the motor from, just incase I need more parts off it. Any help will help. Thanks Jerry
Offline ROSS
  • 1412
Re: New Member here need help with Samurai 1.6 engine swap
« Reply #1 on: January 07, 2007, 08:54:29 PM »
TRAIL TOUGH  ,  CALMINI  ,  LOW RANGE  ,  PETROWORKS  ALL PRETTY MUCH THE SAME
« Last Edit: January 07, 2007, 09:01:43 PM by ROSS »
« Reply #2 on: January 08, 2007, 05:00:46 AM »
Trail Tough do a full circle adapter plate and can supply the wiring too. They also do some nice heavy duty engine mounts although you can modify the passenger side mount.
I got my plate from a UK supplier, there weren't any instructions. I fitted the plate and put the engine in. Then I discovered the two top engine/box bolts are bigger on the 1.6. Now I have to take it out again and drill out the bellhousing  >:(
Offline jrryrog
« Reply #3 on: January 08, 2007, 05:46:38 AM »
Rhinoman, thanks, you may just saved me from the same mistake.
