what is a good transfercase/transmission setup?
  • 1870 Views
Offline tonyman246
  • 58
« on: January 07, 2007, 10:40:21 PM »
i am hoping to build a straight axle 89sidekick 2 door.
but i was wondering what would be a good transfercase/transmission to use? i want the transmission to bolt straight up to the motor OR a transfercase that bolts up to the transmission.
any ideas?
1991 Geo Tracker 33" super swampers + 4" lift + minor fender trimming + locker = unstoppable!
Offline kirknd4spd
  • 333
Re: what is a good transfercase/transmission setup?
« Reply #1 on: January 08, 2007, 11:09:53 PM »
keep the zuk tranny and t-case.
just my $0.02
Offline wezzlegod
  • 227
  • under construction crowler
« Reply #2 on: January 09, 2007, 05:31:30 PM »
toyota t case you can get lower gears for it. its also stronger. go to ottindustries.com. if you want to drive bigger tires than 32s id go with a whole drivetrain swap. im doing it. allready did the moter and trans and duel t casses. going out for testing in 2 weeks.
