brakes, rear...how to adjust emergency brakes?
  • 2515 Views
Offline synergy_58
  • 59
« on: January 08, 2007, 04:55:05 AM »
Hey all,
Where's the best source to get brake parts?  I just took apart my rear brakes and found that the passenger side was locked up.  The adjuster was so tight that I couldn't get the drum off w/o beating it off and destroying the hardware.  The shoew were ground into the drum.
Needless to say, I need all new parts.  The driver's side looks normal.  Why would this happen in such an uneven way?  The emergency brake handle was hard as a rock, I could barely move it.
I called Pep Boys, Auto Zone, and NAPA.  They all have to special order parts (5-7 B-days) and prices varied between 24.60 -149.95 for ONE drum...doesn't seem right.
Any suggestions?
Offline ROSS
  • 1412
Re: brakes, rear...how to adjust emergency brakes?
« Reply #1 on: January 08, 2007, 07:45:50 AM »
CALL HAWK
« Reply #2 on: January 08, 2007, 10:16:19 AM »
Check the cables, you might have one seized.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: January 08, 2007, 10:50:12 AM »
CALL HAWK
Hawk's Strictly Suzuki 888 SAMURAI for the emergency brake cable assembly used and possibly OEM NOS, too.
Tell them Ack sends you  ;)
Alternatively:
Your local Pick-N-Pull may have drums.  It depends on whether you have a Samurai or a TracKick.  Don't get a cable assembly there. You'll probably end up destroying it in the process of removing it.
Ack
