Samurai Pulls Under Heavy Breaking
  • 2353 Views
Offline W.O.T
  • 38
« on: January 09, 2007, 09:43:04 PM »
im pretty sure its a braking problem but im not really sure what to look for.   the samurai drives perfectly straight with no hands on the wheel so i dont think its alignment.  but under moderate braking it pulls to the right pretty hard.  any ideas?  could it just need a new set of pads on the front end?
Offline igofshn
Re: Samurai Pulls Under Heavy Breaking
« Reply #1 on: January 09, 2007, 10:10:51 PM »
Can you say, brake job!!! :) :) :)
« Reply #2 on: January 09, 2007, 10:36:31 PM »
my 88 sammie has the stock brake setup on it and the way the master cylinder works is it applies the brakes in an X pattern not like american rigs sepparating the fronts and the rears in the master, hope this helps, and yes it is normal on a sammie needing a brake job!
Offline W.O.T
  • 38
« Reply #3 on: January 09, 2007, 10:50:17 PM »
thanks for the info.  im sure it could use new brakes ill start with that
Offline RShrimp
  • 28
« Reply #4 on: January 10, 2007, 09:13:07 AM »
You have a caliper hanging up
88.5 Samurai with spring over and 31,s
Americas Oil problem is simple. We just can't seem to check our oil.
The oil is in Texas and Alaska .... The DIP STICKS are in Washington!
Offline JamesG
« Reply #5 on: January 10, 2007, 11:23:30 AM »
Stop running into things and maybe it won't break so much.  ;D
Offline Gary_Hill
  • 288
« Reply #6 on: January 10, 2007, 10:26:38 PM »
Bad oil seal on one side will make it pull to the side that has no oil on the break pad. First thing to check...
Offline W.O.T
  • 38
« Reply #7 on: January 11, 2007, 07:15:00 PM »
i pulled it apart and the caliper and disc were covered in grease.  do you know which seal it is?  i pulled it apart but didnt find anything that looked to be bad.  thanks
