Camber Bolts?
  • 2664 Views
Offline atc_gv
  • 76
Camber Bolts?
« on: January 11, 2007, 02:27:41 PM »
You guys using camber bolts, did you use the ones from boondox? I need some for my 2000 GV.
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Camber Bolts?
« Reply #1 on: January 11, 2007, 05:29:05 PM »
I got mine from Summit Racing.  Screwed up and ordered two thinking they were singles and got two pair.  I guess it worked out as now I'll need that second pair for the XL7. :P
Double check how many you are getting per order. ;)
Offline fgials
  • 80
  • Central Mississippi Suzuki Association
Re: Camber Bolts?
« Reply #2 on: January 11, 2007, 06:25:47 PM »
I hae the ones from Boondox.  I plan on installing soon I will let you know how they do.
Offline bzzr2
  • 1011
Re: Camber Bolts?
« Reply #3 on: January 12, 2007, 08:54:48 AM »
ovalizing the strut holes has worked perfectly for me, i did the bottom hole, seems like most people do the top though.  just a thought...
09 taco reg cab short box 4x4
Offline sergi
  • 307
Re: Camber Bolts?
« Reply #4 on: January 12, 2007, 02:46:53 PM »
I had to ovalize the holes AND use camber bolts. It's a bit negative now, but it rides very well! ;D
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline atc_gv
  • 76
Re: Camber Bolts?
« Reply #5 on: January 12, 2007, 05:33:13 PM »
I don't want to file the holes just yet. I will install the bolts and see how I like it.
Offline bzzr2
  • 1011
Re: Camber Bolts?
« Reply #6 on: January 15, 2007, 07:36:44 AM »
fair enough, the alignment shop told me i was better off ovalizing than using the bolts when i went in.  after a decent summer of moderate off-roading my springs have started to sag a bit and i'm getting a little of this / \ look outta my wheels now and seems i've lost some lift from sagging weak stock springs and spacers.  i think once i replace my stock springs i may need a combination of both bolts and the ovalizing...
