kicker 3
  • 1540 Views
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
kicker 3
« on: January 11, 2007, 06:13:07 PM »
Has anyone on here installed a kicker 3 on there track/kick? I was origanally planning on running a 2wd tracker trans with a sammy t case set up, but it looks like the kicker 3 is the way to go.
If I read the website correctly you will have to just have some drive lines made up along with some extra support brackets for the sammy t case.Correct? Also with the dual case setup you should not have to  get gears, unless you realy want to be low.
Any info on this, or if you guys/gals can direct me to the propper people that would be awesome.
lata
TJ`
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline whitfield
  • 633
  • 4-dr Kick on 34's
Re: kicker 3
« Reply #1 on: January 12, 2007, 05:31:47 PM »
I purchased a Kicker III to do this.  I already have a 4: 1 T-case in my 4-dr Kick on 34" LTB's  I need to have the Sammy case in my drive train to get the lower (Numerically higher) Hwy gear.
As it got close to time to install I ran across a deal on a rock buggy chassis and installed the Kicker III in their with a 1.6L 16v instead.
With my 5.125:1 gear and the kicker III and a Sammy case I was looking at a (Precieved) High range axle ratio of just over 7:1.  I don't remember which sammy case that was calculated with, I'm thinking stock but I also have a 4:1 Sammy and a 6:1 Sammy case.
