Silly question but
  • 2012 Views
Silly question but
« on: January 11, 2007, 08:08:37 PM »
I'm taking off the Calmini 3rd (heimjoint already shot) on my 4dr and replacing it with teh stock 3rd and spacer.
problem is.
I've forgotten which way the 3rd link ball mounts.
which way is forward?
Picture A
Picture B
Spacer made by SuzukHunter
Bought it over a year ago.
Re: Silly question but
« Reply #1 on: January 12, 2007, 10:04:10 PM »
Really? ???
It's been so long that I've seen a stock one on I've forgetton. :-\
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #2 on: January 12, 2007, 10:06:17 PM »
A is correct ;)
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #3 on: January 12, 2007, 10:12:53 PM »
I would double check that upper joint to see if it has enough travel with your spacer installed. I think it will but still for safety’s sake I would pull the coils out and cycle the suspension with the shocks attached. Be sure to check for full up, full down, and flex.
Mike
« Reply #4 on: January 12, 2007, 10:19:28 PM »
A is correct ;)
"WOW" my guess was B
Thanks
I'll check for travel too.
Thanks again.
« Reply #5 on: January 13, 2007, 10:51:25 AM »
I would of guessed B too. I think that Mike guy has never worked on a Sidekick in his life, much less been under one working on it's suspension ::). You better check his credentials  ;D
« Reply #6 on: January 13, 2007, 04:33:36 PM »
Your probley right.
I don't think he's seen a stock set up in 15 years ;) ;D
