Help on Samurai Project
  • 1725 Views
« on: January 11, 2007, 08:56:54 PM »
I just purchased a bone stock zuk samurai and i am planning on making into a dual purpose DD as well as a capable rig.
I plan to invest in a complete 6in SPOA kit from rockyroad, replace the front springs with rears, and put some cj springs in their place. I then plan on puttin a spool in the rear and possibly a locker in the front if my wallet can bare it. I want to run 31's or possibly 32's depending on wether i can fit them and how much flex id be sacrifing. I also plan to invest in a new 3core radiator b/c the one in the sammy now is cracked, a complete calamini exhuast system, and maybe a k&n air filter kit to bring a little spark to the little engine.
Now im attempting to just get my project off to a good start, but im low on funds and cannot afford a new set of gears for the transfer case or ring/pinions to compensate for the larger tires so the questions i have are these...
As far as ive laided out, do my plans seem considerably good for making a capable DD/trail rig for a low price?(open to reccomdations!)
will my zuk be able to push the 31/32s?? on and offroad without having to struggle too bad?
and other there any other things i need to address in this projecT?
« Last Edit: January 11, 2007, 09:22:00 PM by TexasSamurai75 »
Offline Amilla
  • 1076
Re: Help on Samurai Project
« Reply #1 on: January 11, 2007, 11:26:53 PM »
I belive to run springs up front you build a set of springs.
You combine springs from the rear and the front. Cutting them and adding them in.
Im not sure if this is how you do it for a samurai, but i know thats how you do it for a Toyota.
Amilla
« Reply #2 on: January 12, 2007, 04:58:19 AM »
What kind of wheeling do you plan on doing? Personally I wouldn't go for big tyres until I had the gearing to match. I had 33s on the Vit with stock 5:12s and it sucked. It did have more ground clearance but all round it was more capable on the 215s.
Offline costa 05
  • 206
« Reply #3 on: January 13, 2007, 08:55:10 AM »
Had 36 swampers on a sammi had a weber and a calmini tri y did spoa and calmini 3in springs also put a 3in block tube under the springs. Ran great off road now remember I live in Fl. so all we do is mud or trail ride. The damn thing floated it was a blast!!!
when in doubt gas it!!
