Where do rear seat belts mount?
  • 4860 Views
Offline jaybyrd92
  • 30
  • 1992 Suzuki Samurai JL
« on: January 14, 2007, 03:04:44 PM »
I have a 1992 Samurai JL which has never had a rear seat in it. It doesn't have bolt holes or anything. I found a rear seat out of another wrecked Zuk and am planning on putting it in mine.
I took measurements for  the bolt holes for the rear latch, and where the front "hinges" mount. But the wrecked Zuk didn't have rear seat belts. I know where the female ends mount to the seat itself.
What I need to know is where the male ends that retract need to go.
Any help would be appreciated.
                                                 jaybyrd92
Never use money to measure wealth.
Offline costa 05
  • 206
Re: Where do rear seat belts mount?
« Reply #1 on: January 14, 2007, 03:38:15 PM »
Look back by the tailgate should be a bolt hole about 2-3 inches in by the corner of the bed
when in doubt gas it!!
Offline jaybyrd92
  • 30
« Reply #2 on: January 14, 2007, 07:59:11 PM »
Thanks Man. I will check it out.
                                                  Jay
« Reply #3 on: January 14, 2007, 08:37:56 PM »
The bolt hole might have a "sticker" over it, or it may not be drilled at all (probably what you will find).
The cross-brace under the cargo area will probably have the nuts for the seat belt bolts...or are the nuts on the bottom side of the cargo floor??? (I can't remember for sure), but either way........the holes for the bolts will probably need to be drilled through the top side of the cargo bed area.
« Last Edit: January 14, 2007, 08:40:59 PM by Skyhiranger »
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #4 on: January 14, 2007, 10:07:47 PM »
be carefull of the gas tank if you do have to drill. :) just friendly reminder from someone who forgot.
Mean Green Wheeling Machine
